40mph stock set up using 4s 4300 mah zippy lipos. Radared using a cheapy Bushnell unit with the front shroud removed for improved accuracy.
Ghost
Ghost
Some batteries (the cheap ones) do not hold the voltage under load... you'd be suprprised of how much they drop... I have not seen his setup or anything but just by him saying that he got a "no namer" cheap off of ebay tells me that the batteries have a good
chance of being the problem... at least one of the major problems.
Instead of editing my post I just wanted to add that I used a Watts Up meter and measured spikes at its max plus. Last max reading was 100.72 Amps. Is or has anyone been able to log their amp draw using 8xl and k45mm prop?
Ghostofpf1. I sent an MO today to Optics Planet for the same radargun to measure the true speeds on both my moded SV 27 and moded BJ 26. From what I know the Bushnells are quite accurate. I ve seen guys use them in drag racing tracks.
today with ammo 2300,stock speedo, grim 4255 prop, 43 mph i think it is under prop motor seemed hot but speedo was not that warm.
Ctonez is right Kssi. Like he said try the Octura x 437 two or three bladed or a 440 2 blades. Never try a 442 with an AMMO as you may fry the batteries... A grim 42 x 55 is way over propping for a 2 pole AMMO 2300.
or a y536 prop.
alright thanks for the help guys
Mich Maniac I'm putting your set up in my sv and hope to have good speed to post here aswell. Can't wait to test.
SV 27,brushless mini vee,renegade rigger,twinstorm,micro drifter,super hawaii , 1/12 miss budwieser
Not mine, but wow they haul:
http://youtube.com/watch?v=l814TEnb9yw&feature=related
http://youtube.com/watch?v=DCrzMHF3e3c&feature=related
Ammo 2300kv
X-power 100amp ESC
Intellect 2s2p 7.4V 5000Mah
X642 sharpen & balanced
L&R Turn fins
Fortrex101 = 45.5mph (80.5km) will upload video soon
and is rock solid on plane at speed
sounds good showstopper but i think you ll find that 50 mph = 80 kmph
that's right 45 = 72.4kms
Scuffed bottom
X642
2S2P lipos
40.58mp/h
http://www.youtube.com/watch?v=jaVeWKUT_Lg
Faster one, http://www.youtube.com/watch?v=1A0SY_LyZho
-lost my gps on this one, so no readings.
click the "watch in high quality" -thing!
