Cheaper still is to tear those Propel packs down and install battery bars. Believe me, It makes a big difference.
Its the cell itself. Its nuts to buy them when good IB3600 packs are the same price. I have tryed a lot of differnt cells. The IB3600 is the toughest cell, that stands up and does not fail like the 4200's. Well its getting hard to find them now anyway. Cant argue with this, just toyin around...running 6 cell IB3600 packs and a M445. The even 7 cell propel wont touch this. http://s110.photobucket.com/albums/n...t=MVI_1389.flv
PS this exact boat is avail on Ebay http://cgi.ebay.com/ws/eBayISAPI.dll...MESE:IT&ih=020
I think i am going to go back to lipo. I thought these propel batts were the best on earth as for being a NIMH batt. I figured i could use the heavyness of the batteries to adjust the CG. I do need to adjust my trim tabs. My turn fin is directly vertical. Side fins are cocked back a lil.
YES DOMWILSON the link of the propel batterys are the ones i got but mine were custom built and are 7 cell not 6. The guy did a awesome job. Heres the ebay guy who sells them
GET INCREDABLE RUN TIME!!!!!!!!
GET LONG-LONG-LONG RUN TIME & 45MPH+ ROOSTERTAIL POWER!
DONT TAKE CHANCES BUYING FROM SELLERS WITH LESSER FEEDBACK RATINGS! SEE MY 100% POSITIVE RATING FROM OVER 1430 BUYERS!
YOU WILL GET 2 OF THESE GREAT BATTERY'S W/ DEANS PLUGS INSTALLED
SEVERAL OF MY CUSTOMERS HAVE WENT OVER 47MPH WITH THEIR SUPERVEE 27'S RUNNING THESE DUAL 8.4V PRO-RACER PACKS!
THESE ARE A PERFECT FIT IN THE SUPERVEE 27!
maybe you need to move the batteries closer to the transom.
i moved them all over the place. The problem is im not running lipo's and these packs are weak. Also...weak packs and they weigh 15oz a piece. I can run 7.4v lipo packs 4000mah which weigh 7.90z a piece. I think thats the best way, along with tweaking the turn fins and stuff.
i think you are selling yourself short by just assuming that nimh is the problem. i've gone 45mph with my sv and that was using 14cell nimh. lipos will give you more speed, but if you are only doing 28mph on nimh, the batteries are the least of your problems. things may not be trimmed out right... you might also try and find a way to borrow another set of nimh of a different brand and see how those work.
those batteries are surely contributing, but i would be really surprised to see that they rob you of 10mph in speed just because they are lower quality cells.
bottom line, be fair to yourself, and try your boat on a good set of nimh before you spend a huge chunk of change on lipos only to find out your boat is still slow. you need something to compare your "norm" to.
i couldnt have said it better. mine boogies on 14 cells on a balanced 640 and lightly sharpened. when i first got it, it ran wet. maybe you need to make sure the strut is at 0 degree or parallel to the bottem of the boat, few degrees off makes a lot of difference.
I would also say that the problem is your battery. I used it before & the result is very poor. They even over heat after i used it. So maybe try the IB or GP batteries if your not ready to go lipo yet...
Ran my friend Jeff's SV27 today,after doing a few mods for him
Motor esc stock
Batts IB4200 12 cells
Mods are strut angle 2deg down angle
battery placement
and mod X642 prop
first run was 41.5 mph
second run on same cell packs 41.8 mph
you have to excuse pics quality taken on cheap camera phone
Jason
Not bad at all for the stock components. Actually better then most! I'm still waiting for things to thaw out here in Wisconsin for my maiden voyage. I got 2 new boats near x-mas so I'm getting very impatient! Actually I finished the first one like the same day the water froze last fall then I got a new SV for christmas. The only advantage is I've had lots of time to set them up the way I want for spring.
well i ran my 7.4 2S 4000mah packs today and i got 32.8mph on the garmin.
Stock motor
stock esc
Graupner CF45
scuffed bottom
tabs 2 degrees negative
rudder cocked in all the way towards the transom
1 turn fin on each side stock supervee ones...angled back for loose driving
if i run the same setup listed above does anyone know if its worth getting a fiagao 7XL (2,328kv) or the ammo (2,300kv)?
they both are the same price practically......
stock motor is 1,700kv = 27,000rpm
fiagao and ammo 2,300kv = 36,800rpm assuming you are running 16volts (16cell) or 4S.
anyone have any suggestions on this idea that everyone usually does or any experienced boaters?
change your strut to neutral and trim tabs to a little positive and cock the rudder half way to the transom not full under.
i was running the stock setup the boat has for the batterys. I think the terminology or words would be 2S2P. Theres only two kinds right? (parallel and series?)
also since i have researched supervee's i have realized a CF45 prop is a lil too big and the people are right because after i run my lipo's or my NIMH's the motor is hot and speed control is slightly warm. If i got a 7xl i was gonna prop down smaller.
Take a look at this page. It does a great job of visualizing what the P's and S's mean
http://scriptasylum.com/rc_speed/_lipo.html
Don't get me started
IME the 7XL is too hot.
Feigao's KV reading is not the best number to go by when comparing motors...The Ammo's and Neu's turn the advertised KV under load much better. The 7xl will likely burn up, whereas the Ammo will get pretty warm, but not dangerously hot...as long as your prop is reasonable.
The 8XL or 9XL is a safer choice and will give better performance than the stock motor.
Personally, I run the Ammo. You can run it with the stock ESC, but keep run times short, prop small, and check temps often.
I run it with a CC125, I like the headroom.
thats true a cc125 would be good headroom.
I think i will run the ammo 2300kv. Can the ammo 2300kv handle 5S or possibly 6S?
Today i went out to do a speed run and hit a big wave. I usually tape my garmin onto the top of my boat. Always worked fine with duct tape. Now i see why guys put there GPS inside the boat!! I was so mad at my self. Well anyways i hit the wave causing my supervee to do a awesome barrel roll and in the twist in mid air, the garmin flew off and sank to the bottom of the lake. So now i have to buy a new garmin. I thought if you put the garmin in the boat it wouldnt pick up the satellites or maybe it would decrease the signal. If anybody can tell me otherwise please do so, because i don't want to follow my superstitious mistake again.
never had any issues with running the gps in the boat
sorry about your loss
it always sucks to lose something that was not cheap
5s=18.5V
18.5V x 2300Kv = 42,550 RPM's
That's too many rpm's to try and spin in the water.
5s or 6s is a really bad idea IMO and will likely be the same as lighting your money on fire just to see it burn.
Acquiring the Satellites before putting the GPS in the boat is advisable, but yes, the GPS will be able to communicate through the fiberglass hull.
"I usually tape my garmin onto the top of my boat"
Remind me never to loan you my GPS, or Camera, or dog.... there is always aquacraft scooba gear to look for it...new hobby...
I know guys who run 5s on the stock set-up but not 6 and that's only 1800 or 1600kv so yeah I think you'de be pushing anything above 4s with a 2300kv ammo! But if your made of money and like to gamble more then I do go for 5s and prop down but watch your temps and don't push it with long wide open runs just give it bursts! let us know if you try it!
ok i might try it. I can go 4S , 5S, . I will let you know. What ctonez said 42,000 rpm would be too much for water and something might fry. Well it was a thought. Defenately would need a beffier ESC at least 100amp or more. I will have to buy a gps soon to try it. So i will let you know.
I guess it's time that I picked up a GPS so that I can be a bit more scientific in figuring out which setup is actually the fastest. Can you please tell me what brand and model GPS you are using?
Thank you very much.
That looked about 30ish to me.
Try the GARMIN Forerunner 201 gps. It's slightly larger than a watch, waterproof, and 69.99 on ebay. I just tape mine right on top of the boat. Have fun.
FWIW, I think at the Valdosta SAWS this past weekend there was a verified 49.9 mph for a two way average record time with a SV. This was in the "Open" class.
