Today I finally got my miss g in the water for her maiden voyage vs my buddies spartan... WOW what a great match up... he was running a stock spartan on 6s I on the other hand had I highly modified miss g with hobbywing 150a esc 4074 leopard 2200 kv motor offset rudder and octura x642... I also added some great stuff window and door foam non bowing worked great and reinforced the canopy with some fiberglass. I also set my batteries at 9in from transom. Wow was I impressed... I set the drive dog gap about 1/8th inch left everything else stock the way it came so there is still room for improvement but absolutely no wah wah so thank you everyone for all your suggestions cause they worked great!!!! I also forgot to use hatch tape but had all most 0 water in it till the end when I lost my antenna tube so I had at most a teaspoon.. I was very impressed at how well sealed it was.... it was a very close race... out of the hole the spartan had me badly untill I plane up at about 5-6mph then she was gone... over all my mg was maybe about 1mph faster after I was on plane but he was also struggling with death wobble half the day so in the videos it was actually closer than it looks great match up!!! When I get my 2 3s lipos this weekend ill try it on 5s then 6s. We both used 5000mah 40c batteries. Ill try to post videos as soon as I can figure it out but over all very impressed considering I made no adjustment once she hit the water very very happy!!! My next run ill also try a prather s220. oh and the best part about my run today had to be the low temps even with the 40mm water jacket was only 72* and the esc was 69*
