Results 1 to 19 of 19
Thread: flysky radio
    Dec 2010
    ks
    403
    Default flysky radio
    have a flysky radio i put in a mono that i just finished buiding, its a gt3b system, ran the boat a few passes to get glitches out and the dang thing is dead now and not getting a signal, anyone run these things?....it has a fail safe built in to reciver
    Jul 2007
    Or
    626
    I have one. Are you getting any lights on the receiver at all?
    Did you get the receiver wet?
    SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150
    NJ
    1,322
    Quote Originally Posted by dano1 View Post
    I have the flysky i never had one problem i run them in 10 RC models.... try rebinding it make sure ABS brakes are off on the radio.
    also with the gtb3 radio after every setting adjustment you make you have to press the enter rotery button down or your settings won't be stored.
    Also when switching to a new model you must first switch to the model press enter and shut off and turn back on the radio or your models settings won't load correctly and end point settings change and maybe trim settings.
    WWW.PPRSLOTS.COM
    Dec 2010
    ks
    403
    Im getting no lite on the reciever now, no...it didnt get wet, ive run it on another boat with no troubles, it just stopped responding like batterys were dead, im running the bec connected, i really havent dug into it yet for trouble shooting but im surprised it just quit like it did, i was in a no wake zone...ha ha....and it just stopped. The only thing i dont like about the transmitter is its easy to make a missadjustment in hand when your running, the grip has the buttons on it, the radio has 2 passes on it
    Dec 2010
    ks
    403
    Im only running one boat on the system also, ill check the settings but as i stated ...its strange it just stopped like it did
    NJ
    1,322
    don't worry about water these flysky 2.4 RX's can run under water they don't get harmed by water.
    WWW.PPRSLOTS.COM
    NJ
    1,322
    I put a flysky modual in a ko propo mars , mars R and ex10 helios great radio's with all the features you ever need and no problems but you get to buy the cheap FS 2.4 $7.00 RX's to boot!! no prblems with these set ups!!
    WWW.PPRSLOTS.COM
    Jul 2007
    Or
    626
    Dano,
    Are you sure your BEC is good and providing between 5 and 6 volts?
    If it is then you may have a bad receiver.
    Dec 2010
    ks
    403
    im going to put a external battery pack in it and try it again to see if its a bec issue, like i stated i just got the boat running so it could be several things, glad someone else is running these radio's....there a tad confusing setting up first time
    NJ
    1,322
    Try that it may work.
    Here is my KO converted to flaysky 2.4 radios... also am doing a mars R!
    WWW.PPRSLOTS.COM
    Dec 2010
    ks
    403
    The esc is out of my kos....that could be a serious problem right off the bat, i have a 125amp turnigy that has something funk going on with it but i reprogrammed it so i may try that one again, where should the stinger be setting on that little jewel?, im about level with the hull now.....mabey a tad down
    Dec 2010
    ks
    403
    Its the prince knock off i bought from brad
    Dec 2010
    ks
    403
    bec bad in esc , put a external pac in and all came back online, thanks for the info guys
    Jul 2007
    Or
    626
    Glad to hear it was just the BEC in the ESC.
    Although, I am sure the ESC cost a lot more than that $7 receiver!
    Got to love the price, i just outfitted the last 5 of my surface RC vehicles with these receivers for less than i sold my last used JR RS300 synthesized receiver for on eBay.
    NJ
    1,322
    Yea pick up a old KO PROPO radio for 60 bucks or so used and buy the flysky modual put it in and you have one of the best radios going!!
    Got to love it!!
    WWW.PPRSLOTS.COM
    Oct 2008
    9,488
    Quote Originally Posted by SweetZ28 View Post
    Got to love it!!
    got a link to one of these?
    NJ
    1,322
    The flysky modual is not a direct drop in you can make it work with KO radios by just soldering 3 wires and a resistor.
    WWW.RCTECH.NET search for ko propo in the for sale section keep looking for a few days some will come up. or on e-bay...I think there is a nice Mars R on e-bay now the marrs R is the best as it holds 20 models.
    found on E-bay this is a very nice radio if you get a ko radio let me know i will show you a thread on what you need to fit the 2.4 flysky modual in it.
    http://cgi.ebay.com/KO-PROPO-EX-1-MA...item27b9a719d1
    WWW.PPRSLOTS.COM
    Dec 2010
    ks
    403
    Bad thing about getting the model i have is the back order wait..............took a month and a half before i finally got mine, there real popular radio's and yes....the 7.00 bucks for extra recievers is a tasty deal by far
    NJ
    1,322
    If you have the GTB3 you must do this:
    WWW.PPRSLOTS.COM
