Results 1 to 7 of 7
Thread: 15" Hydro
    Oct 2007
    1,302
    Default 15" Hydro
    Greetings,
    I'm open to opinions on what would be ideal to run on an 15" Hydro. Here are the specs as what I have that may be used:
    ESC:
    Hobby Wing/TURNIGY
    Constant Current: 35A
    Burst Current: 190A
    Resistance: .0015 ohm
    Battery: 2-3S Lipoly
    Batteries: 3s 20C Zippy 1300, 1800 and 2200mah
    Motors: All are 2~3s capable (all inrunners)
    2040: 2600 kv, 2700 kv, 3860 kv, 3900 kv 4850 kv
    2848: 3900 kv
    2445: 2900 kv, 3860 kv
    Props: 4x27mm, 4x30mm, 4x31mm, 4x32mm
    Which would be ideal reliable setup for good speed?
    Thank you kindly.
    Aug 2009
    tx
    3,534
    I have a rigger with an 2600 outrunner 1300 mAh 3s on a 431 prop and it hauls I probably use the 2445 motor
    Oct 2007
    1,302
    Quote Originally Posted by Alexgar View Post
    Thank you for the reply. I should say the motors are in-runners. Need to Edit original post.
    Oct 2007
    1,302
    Would you think with the 2445 it would have to have a water cooling jacket?
    Oct 2007
    1,302
    I'm going to try the 2445 with a 427 and work my way up with the props and see.
    Nov 2007
    6,927
    You should easily be able to run a 30-32mm prop on the 2445 on 3S!
    Mini Cat Racing USA
    www.minicatracingusa.com
    Oct 2007
    1,302
    Quote Originally Posted by sailr View Post
    Hey Jim,
    Thank you for chiming in, you are awesome. Now that I know what prop, I'm eye balling this motor: http://www.hobbyking.com/hobbyking/s...dProduct=15186
    What do you think? Would I need a water jacket on it? I found a way to make a 28mm jacket (that I already have) to easily fit this 24mm motor but don't want to use it unless have to. Or would a 2900kv 2445 on 3s be better?
    Thanks again.
