Results 1 to 4 of 4
Thread: Programming Module timing setting
    md
    109
    Exclamation Programming Module timing setting
    What is the difference between the 2 settings ? and which allows the best top speed?
    Which on/off voltage setting should you use with lipo batteries ?
    Feb 2011
    tx
    97
    i run mine on high voltage cutoff,and linear speed
    md
    109
    Which timing setting ? timing low or timing high ?
    md
    109
    Just got a call back from a tech at horizon hobby and was told the boat can use either timing setting.
    High will have increased performance and less run time and Low timing will have less performance and longer run time.
    Also to use the high voltage cut off setting.
