Results 1 to 20 of 20
Thread: Lifepo4 0850 mah 6.6v receiver pack
    ma
    8,693
    Default Lifepo4 0850 mah 6.6v receiver pack
    Any one use the Life packs for rx power? I have had a couple of people ask me to carry them.
    Steven Vaccaro
    Nov 2008
    DE
    2,322
    I have one of those (Hyperion LiFE 850) for my P-Mono and would like to buy another one....I have not tried it out yet...still finishing my build...
    -Kent
    "Will race for cookies!"
    IMPBA D12
    My Gallery: https://forums.offshoreelectrics.com/album.php?u=1738
    647
    I had one that worked great until I left the switch on, it drained all the way down and now won't take a charge. I would buy another one if you stock them.
    Jan 2008
    VA
    3,070
    If they're Hyperions, I would buy some from you.
    Jul 2010
    544
    I've made one from a B&D VPX battery pack, which contains 2 A123 1100mah cells. I think I paid $20 or so, but I can't find more VPX packs around (discontinued)
    For the right price I would definitely buy one or two, either 1100mah or 2300mah cells.
    Jul 2010
    3,663
    I have (5) 700mah 2s Life packs I use for rx packs. I was concerned about them only being 700mah, but after my first run with one, I charged it and it took 42mah, so it doesnt take much. Im sure if you carried them you would have a hard time keeping them in stock once everyone caught on.
    Dec 2009
    AL
    20
    I have been using them for over a year now, all my boats have them. These things are great, and pretty good about taking abuse also. Nothing like those 5-15 min. charges either! Hyperion all the way, the Hobbico ones are pretty good also, they make a 200 mAH one that works for the micro boats.
    Nov 2007
    6,927
    I use them. I also use a cheap chinese BEC as a voltage regulator as I learned the hard way that some servos don't like the higher voltage of the LiFe packs. Mine are hyperions.
    Mini Cat Racing USA
    www.minicatracingusa.com
    Nov 2008
    DE
    2,322
    I am also using a Hyperion servo with the LiFe pack...It is an Atlas HV.
    IMPBA D12
    3,117
    I would be interested in a few as well.
    Mike
    ma
    8,693
    Thanks for the imput. My only issue with them is that they require an adapter like below.
    More info on the rx packs can be found here.
    http://www.hyperion.hk/dn/fg3radio/default.htm
    Steven Vaccaro
    9,402
    The balance taps would be enough for Rx power, main leads aren't that useful.
    I've been using 2S 1000mah lipo packs with Ubec for a while. I don;t like tapping into an esc and the extra wires everywhere.
    I like the LiFe voltage though. In some boats I would not need the Ubec then.
    3,117
    I agree, I don't like the idea of needing an adapter. It's completely uncessary.
    Mike
    ma
    8,693
    Its another wire and connection that could fail, not to mention the extra money for an adapter.
    Steven Vaccaro
    Feb 2011
    92
    it needs to just charge through the balance tap, then have a standard servo power plug rather than the bullets. that would be ideal.
    Nov 2007
    6,927
    I use them all my non-bec boats and airplanes. I probably have about ten of them.
    Mini Cat Racing USA
    Jan 2008
    VA
    3,070
    I didn't like the extra connector at first but I don't mind it so much any more. I keep the three pin "J" connector plugged into the receiver at all times. The Hyperion connector is very beefy. I rather pull that on and off 50 times at the battery than doing that to the J plug at the reciever or receiver switch.
    Just my opinion.
    Nov 2008
    DE
    2,322
    Amen to that bro!!
    IMPBA D12
    ma
    8,693
    Quote Originally Posted by Nautiboyz View Post
    Just my opinion.
    Thats a great observation! i feel better about getting them now.
    Steven Vaccaro
    Nov 2008
    DE
    2,322
    Hey Steven...I just noticed that you got these in....Just ordered one from you for a backup...Thanks!
    -Kent
    IMPBA D12
