Results 1 to 5 of 5
Thread: Battery connection on myP1
    Feb 2011
    AB
    55
    Default Battery connection on myP1
    Another newbie question
    How do I connect 2 lipo packs to my esc in my P1 as it only has a spot for 1 battery to hook up coming out of the esc?
    Thank You
    7,279
    Jun 2011
    AB
    what kind of plugs does it come with? Can they be switched to traxxax plugs since they already have the adapaters to run parallel and series? or is there another way without switching the plugs?
    May 2011
    36
    unless you make an adapter I would just snip the venom plug and solder a traxxas or deans on it....
    thats what I did... then I made a series connector to run 2 batterys...
    Aug 2011
    Dual 5000ma LiPo's (I have Venom's and Turnigy's) can be run with a simple battery wiring adapter and STOCK ESC and motor? THANKS for the answer!
