Results 1 to 3 of 3
Thread: Aquacraft 36-56 1800kv - Y or D wind
    Feb 2011
    AB
    775
    Default Aquacraft 36-56 1800kv - Y or D wind
    I just finished upgrading a pair of original SV27's with the 1800kv motor from the SV27R and Turnigy 120amp ESC's.
    Wondering about the timing setting so would like to know if anyone knows for certain if these motors are Wye or Delta wound?
    If I can't find out I'll start a low timing setting and work my way up while checking amp draw and temps. But would be easier if I knew the wind configuration.
    Kevin
    3,117
    Just an FYI, but on the Tower website it lists the stock controller at 10 degrees of timing...
    http://www3.towerhobbies.com/cgi-bin...?&I=LXZGW7&P=Z
    Later,
    Mike
    Feb 2011
    AB
    775
    Thanks Mike.
    The Turnigy doesn't have a 10* setting, but I can use 7.5 or 11.25 as a starting point and go from there.
    Kevin
