Results 1 to 4 of 4
Thread: Ni-MH vs. LiPo setting from the factory
    Feb 2011
    TN
    18
    Default Ni-MH vs. LiPo setting from the factory
    Ok, those of you in the know, please help clear this up:
    In the instructions included with the boat AND the PDF found on the ProBoat site it clearly states
    "Be sure to use a PRB3311 Programming module to adjust the cutoff voltage when
    using Li-Po batteries to protect against over discharging the batteries.
    HOWEVER, on the Proboat website, in the "Tech and Spec" section, it states:
    Tech Notes
    The 60-amp electronic speed control is factory set in Li-Po mode.
    Which is it, is it set for LiPo OR is it set for Ni-MH
    Do I need to get the programming module just to play it safe?
    Feb 2011
    TN
    18
    Anyone?
    Bueller...Bueller...
    Sep 2010
    MN
    10
    I was told by Horizon tech support on the phone that the ESC is programmed from the factory for LiPo's.
    Mark
    Nov 2010
    ca
    254
    the esc is set for lipo's from factory, but i have the module and used it to make sure it was and to adjust timing, cutoff and throttle settings to linear. But as i stated i already had the programmer from having to set up my MG
