Originally Posted by
RaceMechaniX
The idea behind the flooded stuffing tube is to allow vertical moving of the strut. If you just had the stuffing tube pass through the transom and it was a tight fit so it sealed the water then it would be impossible to allow for any strut adjustment. In nitro and gas boats we just make an oval hole in the back and leave it open for water to drain out. In the FE boats, we have to seal it, so we install a larger tube which the stuffing tube fits in. We epoxy the tube in the rear on the OD to seal the tube to the transom. In the front of the tube, we seal the stuffing tube to the ID of the big tube. Now we have a sealed tube, but with th extra length between where the stuffing tube is sealed and where we have the strut we have enough bend allowance in the stuffing tube to make strut adjustments. The stuffing tube is supported near the motor by the expoxy and its supported at the rear by the strut.
Hopefully that all makes sense.
