Right here in this thread: https://forums.offshoreelectrics.com/...ight=1717+sale
Brand new.
Sweet! Hopefully she fits. May have a clearance issue with the O.D.
In fairness he did say lower kv.
To the OP:
The idea of running higher voltage/lower kv is to reduce current draw and run bigger props. Your setup will generally run cooler when acheiving the same RPM, and you will have longer runtimes with the same mah.
You have to keep in mind the room you have in the hull and the weight of the boat with all those batteries though.
Yeah, that was badly worded on my part too.
Bet the 1717 and a jacket will fit
You'd better support the end of that bad boy. All that weight hanging from a plastic mount may not last too long.
Diameter reduced, back- cuts, balancing and detongueing , harpening, 42x55 -- 40x55
connector 4mm Gold
cooling hose 1/4x.170 O.DxI.D
4S 39.2mph
5S 48.7mph
6S 57.5mph
