Results 1 to 5 of 5
Thread: 4s lipos in series
    Dec 2010
    ks
    403
    Default 4s lipos in series
    thinking of running two turnigy 5000 mah 4s 40c packs in my genesis, esc is 180 seaking and a leapord 4082 1500kv turning a x642, will system handle this load? running in series.
    May 2010
    MO
    3,278
    A little inspiration from Howard?
    Jan 2008
    VA
    3,070
    If I understand you correctly, you want to run two 4S packs in series. When you run two 4S packs in series, you're feeding the controller and motor 8S worth of voltage. I believe the Seaking 180 is only rated to 6S so if you run that set up, expect your controller to
    Nov 2008
    DE
    2,322
    "Will race for cookies!"
    IMPBA D12
    My Gallery: https://forums.offshoreelectrics.com/album.php?u=1738
    Dec 2010
    ks
    403
    ok...nuff said...lol....passing on the idea
