Page 1 of 2 12 LastLast
Results 1 to 30 of 53
Thread: Aquacraft Motley Crew Cat
    Dec 2009
    KY
    18
    Default Aquacraft Motley Crew Cat
    ::Gurus predictions on the new CATfrom Aquacraft, due from Tower early April?
    1. Top speed stock?___________________
    2. Will it run smooth without any aberations unlike the M.G.
    3. Will you have to replace the rudder and upgrade flex cable per M.G?
    4. Will you have to replace everything in it to be fun like everything else
    that comes down the pike with the possible exception of SV 27
    Basic cost $350
    Lipos 150
    Upgrades 300
    Total $800
    Dec 2009
    KY
    18
    [IMG][/IMG]
    WA
    8,335
    MG Jabs are completely uncalled for. Why can't you just appreciate what AQ has produced, if that's your thing, without having to cut down other people's hard work??
    1) 40-42
    2) MG runs fine when you know what you are doing with setup. I suspect the MC will work the same way.
    3) No need to change the rudder on the MG if you don't want to, and the cable is fine. I suspect the MC will work the same way.
    4) No... again, if you know what you are doing, you are likely going to be able to get more out of the MC with setup, good batteries, and a correct prop.
    Darin E. Jordan - Renton, WA
    Cool
    I tested a prototype last year. Based on that experience:
    1. 36-38 mph, easily increased 6-8 mph with a different prop.
    2. Probably, although I do not know what differences there will be between the prototype and the production boat.
    3. Running gear is basically the UL-1 stuff, no problems with that.
    4. No silly boy. This boat is extremely fun right out of the prototype box. Again the production may be slightly different.
    Your glass-half-full approach is just so boring......
    May 2010
    MO
    3,278
    Predictions arent necessary. Buy one for yourself and find out.
    Jan 2008
    Mo
    2,716
    It is a little disheartening when buying these RTR boats that they are not handling better out of the box. This is why these questions are coming up...people are now worried. Look at other forums...EKOS, etc.
    We have seen at least 3 that needed extensive mods just to run close to what they promote. This is no way to get people that HAVE to buy RTR rigs starting in the FE fun world.
    We should not expect them to offset rudders and fix cracks or wonder why their boat is full of water from a cooling can that could have been 100% for $6.95.
    Sorry but I tend to agree with the poster that a little more R&D should be done to make sure the boat runs out the way it is intended.
    UL1....do you really know how many when back because of issues with water cooling, cracking, strut bushings, etc?
    We are skilled in this and most are on this board. But you can't do this and expect to not get some crap from newbies.
    WA
    8,335
    Quote Originally Posted by Jeff Wohlt View Post
    If you had any idea how the process works, you would understand that NO amount of R&D, short of Grim or I building and assembling each boat ourselves, can make them 100%... NOT for the low, LOW price that these things have to sell for. Once we send the final, VERY R&D'd versions to the manufacturers, it's out of our hands.
    The phrase "would bitch if hung with a new rope" comes to mind.
    We have some FANTASTIC RTR options out there... complain if you want, but it's only getting better each year. Lest we forget what USED to be available (if anything...)
    All that said... I can promise you that, if it's within our control, I KNOW that both Grim and I, and everyone else involved, is trying like CRAZY to make these boats be satisfying, right out of the box. I believe we have been getting it pretty close to right lately.
    No amount of R&D is going to make up for a user not taking the time to make the necessary adjustments. All we can do is get it right based on an AVERAGE situation, and provide enough adjustments for the end-user to tailor the setup to THEIR situation.
    If that's not good enough, then I don't know what to tell you.
    Dec 2009
    KY
    18
    Hey Darin, Larry, & Fluid or is that Moe?
    Sitting here with my glass half full of fine Kentucky bourbon, gazing on my backyard lake. Ordered a Motley Crew from Tower, the day they became available.
    Running, crashing, rebuilding and having a hell of a time with my: Pursuit, thanks to Diesel and Jan, Traxxas Spartan, Supervee 27R, not a Spektrum in sight. I embrace RC Boating as a plesant mental illness but draw the line at religion. Sometimes I know what I'm doing. Seem to be getting some dialog, which was my intention.
    Lou
    Jan 2008
    Mo
    2,716
    You seem to be using excuses....the old rope issue is nothing but some lame excuse to get the attention off quality. I would prefer a new rope but any will do...it is how you use the rope....knot on the side or behind the head. One does it right and one does it the wrong way ...which is sloppy and you strangle instead of having your neck snapped...the right way. But enough with that horror.
    Bringing in the money issue to sell something is just telling me CHEAP is poor quality. Have you seen the replacement parts on the UL1...a can cooler for the that kind of money...do car makers build cars to last forever...nope...parts and service is where the money is.
    I can tell you after a proto is tested and items are made for production then inspected by the buyer BEFORE final approval and manufac process begins you also should get a production model to test AGAIN. You should have had this option. Maybe HH was really the final say and inpectors....I do not know.
    ...do we just throw the blame on China? Do we blame design and final protoype testing on you? Wrong wound flex cable? Did you really get a final boat "from" production to test, run, inpect parts and all that...since you are the designer then seems you would have had a hand in this with HH for final sign off.
    I started out just picking on all the parts RTRs with issues but seems we are on the MG and I apologize for that but he who puts up needs to back it up.
    This is NOT personal to you, Darin...just help me understand. How this can happen instead of telling me I do not not understand production.
    Sorry guess it is really just another friggin toy boat...maybe we should just chaulk it up to more china crap that can't follow specs. Not our fault.
    Cool
    Well, a couple more added to my ignore list. Good luck boys.
    WA
    8,335
    BS... I'm not making excuses... I'm telling you how the things work. I don't have anything to make excuses for. These boats from Aquacraft and ProBoat are HEADs and TAILs better than any RTRs we've ever had available, and they keep improving.
    You are making assumptions that this doesn't ALREADY happen! WHY do you think the Stiletto delivery was delayed?? OH, yeah... you buys BITCHED about that too... Perhaps there MIGHT have been a good reason??
    YES, I DID get a final copy, and I DID check the cables, and it WAS NOT reverse wound... I have NO control over how they translate a final approval into a production process. Either way, BIG DEAL! Horizon and ProBoat stepped up BIG TIME and get the problem fixed as SOON as they possibly could. If that's not good enough for you, again, rope...
    Well... I'm taking it personally, and you do NOT understand the ins and outs of dealing with Chinese Production, as clearly illustrated by this post. WHY do you think that things change in the MIDDLE of a production run (UL-1 motors, BJ26 Motors... etc.)?? Do you think that's planned? Could it be sourcing?? Could it be production mistakes? Stuff happens, and YES, it might JUST be possible it's out of some of our hands.
    This "designer" stuff is a HOBBY for me... I'm not paid staff... I'm not on-site... I do this stuff in my garage, in my spare time, and I don't get to go to the production facility and inspect every boat off the line. You don't have the $1,000/ boat that that would cost if that's how things were done.
    Stuff happens, and when Grim, or I, or whoever, gives our final buyoff on a design and production sample, it IS possible that things can be "altered" after that point. It doesn't happen all the time, but it does happen (flex cable, turn fin glass, Stiletto issue that none of you knew about because I caught it on the first production sample and set the fixing process in motion, causing the delay in availability... ) We do our best...
    And, by the way... both the Stiletto AND the Geico do EXACTLY what they were designed to do. They go 35-36 MPH out of the box, and MUCH faster if you know what you are doing. They will run in their Out-of-the-box configuration for decent runtimes, without risking the electonics, and they run and handle well in that configuration. AND, they can both be improved upon by users inclined to do so, with simple upgrades that don't require a lot of modeling or boating skill to achieve.
    Sounds like pretty well designed base platforms to me...
    Dec 2009
    KY
    18
    Talking
    Fluid,
    Passive-Agressive is a sum zero game, besides you can't
    ignore quality concerns. It's an elephant in the room.
    7,279
    Sepeculation is the fools way to feel important.
    Only a few of us have seen/run/raced against this boat.
    Has anyone else had this boat in there hands? I think not.....as to quality issues.....there is no elephant in the room for this new boat as no one has one.
    Another stupid thread that leads nowhere.
    Jan 2008
    Mo
    2,716
    Well thanks for helping me understand...more. I do understand changes in production and I do understand that you took it personally. Sorry for that. I am thinking of the newbies and what it does for getting them going. Maybe slower is the key.
    Fluid, I am so surprised by your response. Just ashame you have that attitude to just turn and off people like a faucet.
    WA
    8,335
    Where is the "Like" button??
    Well stated.
    Dec 2009
    KY
    18
    The elephant is the lack of quality delivered by Corperations selling RTR RC Boats. Why are you opining on a stupid thread? Any money in the game?
    7,279
    Why are you opinioning on a product you know nothing about?
    ma
    8,693
    Quote Originally Posted by louleslie View Post
    Basic cost $350
    Lipos 150
    Upgrades 300
    Total $800
    Did you own a MG? I have one and its great.
    I played with the offset rudder and all that and still think its just as good stock.
    I dont expect perfection for the cost of a entry level race boat. NOTHING is ever without the chance of issues.
    Oh and about the comment on the SV, (and I love my 2 SV27's), have you owed one of those? It takes some time and tuning to tame one. Thats why I enjoy the hobby.
    Short and long of it is if you want a perfect boat there are guys out there that with build on for you for about $1k-2K.
    Steven Vaccaro
    Dec 2009
    KY
    18
    Doby,
    I was bored and wanted to piss off
    some uptight person who always
    parrots the company line. Over and
    out.
    Lou
    May 2010
    MO
    3,278
    This useless thread needs to be deleted.
    Dec 2009
    KY
    18
    I agree
    7,279
    I agree
    Just go away.
    Jan 2008
    Mo
    2,716
    I was not even speaking of the new cat...i think it will do well. Just more general about some past rtrs and some issues they have had...Ul 1 being a main issue. I do own a MG with a 4074 2200 and i am pretty certain i wont be moving the rudder..it is not rocket science.
    So chill, please...nobody is cutting your designs, hardwork or efforts. It helps grow the industry and as long as people do not have major issues then it is good for all.
    Dec 2009
    KY
    18
    Default Au revoir
    Doby,
    I'm coming after you and your dogs.
    Lou
    18-foot fully robotic patrol boat prototype. Note the diesel powerplant and numerous control devices and electronics.
    7,279
    Well at least he's now on a different topic........threats and diesel boats....
    Feb 2011
    92
    almost hate to reply to this and bring it back "on topic" but I'm new to FE and I have a MG. I'm pretty much their target consumer for these boats. I can say I'm nothing but happy with my MG. for ~300 I'm running pretty close to a fully upgraded EKOS and Genesis that are also in my group of friends(they're definitely faster but they also have a lot more money into their boats). My MG out handles them in the corners though. MG and MC do just what they are intended, they give a great base to start from for a reasonable price and if you really want to go faster they take well to upgrades.
    sounds like some of you guys are expecting stuff more like this for your RTR's: https://forums.offshoreelectrics.com/...ad.php?t=21765
    He'll build you one if you really want it and I'm sure it will live up to all your RTR expectations(or maybe not???) but it will cost you a LOT more than MG or MC.
    Oct 2008
    9,488
    maybe this has to do with the flop of a mono traxxas came out with
    but AQ and Proboat gots their stuff together!!!
    Nov 2008
    WI
    662
    Default sorry.. off topic..
    Jeff W
    Could you please let me know (you can pm me) what problems you had in particular with your UL-1..
    Grim
    Jul 2010
    409
    Let's put this speculative thread on hold until the MC is available and there is some real-world data available...JMHO
    Support US hobby suppliers
    Oct 2008
    9,488
    I think this Cat has one a race or two last year during development?
