Results 1 to 12 of 12
Thread: Need info on "Servo Savers"
    ca
    6,962
    Default Need info on "Servo Savers"
    I've seen these critters advertised , seems mostly for cars. Thing is that my tunnel will flip & the resultant pull when the lower unit slaps the water takes out my servo. Is it possible to adapt a servo saver to my application with a push/pull servo arm ?
    Thanks,
    Tony
    Nov 2008
    DE
    2,322
    Hmmm....not sure about this, but does seem like a good alternative to loosing servos. Are you looking to obtain one as I should have one or two laying around? I know the one's I have are made to fit Futaba servos...LMK...
    -Kent
    "Will race for cookies!"
    IMPBA D12
    My Gallery: https://forums.offshoreelectrics.com/album.php?u=1738
    ca
    6,962
    Quote Originally Posted by HOTWATER View Post
    -Kent
    Kent, I'm using servos that take Futaba arms. Would it be possible to show pictures of how they mount/fit ?
    Thanks,
    Tony
    Nov 2008
    DE
    2,322
    Thanks,
    Tony
    Sure!...here are a couple of bad pics (LOL!) of one mounted on a Futaba servo...
    IMPBA D12
    Ga
    5,267
    This may work for you Tony. http://www.servocity.com/html/122ss_double_end.html
    I have seen guys use quick links (less the screw), fuel tubing, and lock collars.
    The boat is hauling the mail, Herb would be proud!!
    Good luck!
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    ca
    6,962
    -Kent
    According to what I see, it seems like I could get one to work. What kind of a transaction do you have in mind ? Edit : OOps, I'll need a double arm like the one Doug suggested, $ 6.95 at servo city; I think I have about that much left after WW VII !
    Feb 2010
    12
    Quote Originally Posted by D.Smock View Post
    Here is a pic of how I did something like this..
    In this case it is for a throttle servo for a gasser that vibrates pretty bad.
    Marcel
    Apr 2009
    BJ
    251
    Out there are shaft type servo savers for rock crawler trucks. I use to have those in my G1 crawler. You made think they might be suitable for boat rudder links too. Surely they are a bit thick thus may need some mod in the rubber boot.
    ca
    6,962
    Quote Originally Posted by Himalaya View Post
    Where can I find them ?
    Dec 2009
    on
    2,187
    http://www.tcscrawlers.com/Ofna-Heav...r-p-16255.html
    how bout this one, for over 200 oz/in servos.
    ca
    6,962
    Quote Originally Posted by siberianhusky View Post
    Thanks. The one Doug suggested looks more applicable since I use a push/pull config rather than a single arm. I'm giving the "fuel tubing" solution some thought as well.
    Apr 2009
    NO
    248
    If it was me I would consider trying one of these used in large scale rc cars.
    http://www.rc-car-online-shop.de/cgi...-servo%20saver
    Here is also one
    http://www.rc-car-online-shop.de/cgi...0servo%20saver
    With ball bearings
    I will require some modifications to your steering system but the saver is very durable and accurate.
    Anbjørn
