Page 2 of 7 FirstFirst 1234 ... LastLast
Results 31 to 60 of 184
Thread: HK Vanquish
  1. #31
    4,204
    Quote Originally Posted by GP73 View Post
    Hey Diesel, are the trim tab mounted flush with the hull?
    The trim tabs are mounted slightly below the hull. I will be moving them up so they are flush with the bottom of the hull.
    Quote Originally Posted by Daniel2000 View Post
    then would you recommend to run a 5s with a higher kv motor?
    like the 1450kv or the 1500kv or even 4s with the 2200kv?
    that would put the ESC in a safer voltage zone?
    since I already have the ESC, I would like to still use it and make it last for a bit, and not burn it in my first run
    and thanks for the advise
    I think (not 100%) sure Forescott ran a 180 with a leopard 5692 on 6s with good results. Like I said it's hit or miss some have had no problems others many problems. I just won't be risking it. The 2200kv would be too much kv for a hull this size IMO. I plan on running the 1500kv on 5s & 6s. You maybe able to get away with the 1500 on 5s on that esc. Not sure the speeds though which is why I plan on trying both 5s &6s on that motor. Hopefully that makes sense.
    - Diesel's Youtube
    - Diesel's Fleet
  2. #32
    Jul 2010
    544
    Bummer, I guess I'll have to drill new holes in the hull to get that...
    But thanks for letting me know Martin!
    On my Osprey their about 1.3mm above the bottom of the hull when pulled all the way down & about 3.5mm above when lifted to their highest. Martin.
  3. #33
    Nov 2008
    Ql
    3,169
    Martin/ Diesel/GP73.
    Trim tabs are best bolted on about 1mm above the bottom of the transom.
    They cause less drag that way.
    You may be able to slot the holes in the trim tabs rather than try to drill new holes in the transom. Maybe?
    Paul.
  4. #34
    Jul 2010
    544
    Yes, that's what I was thinking initially. I'll take them apart again and check how much I can drill there. I'm not going to run her for a while anyway, need to reinforce and put rails first.
    I can't believe they would screw up something that simple though.
    Diesel, have you seen the propeller they ship with it? What a joke...
    Quote Originally Posted by 785boats View Post
    Paul.
  5. #35
    4,204
    Paul.
    I think I should be able to just slot them and slide them up. I will see what I can do and reference the 1mm spacing you suggested. Haven't had any hobby time lately to really check it out.
    I didn't even take it out of the bag yet lol.... I have 0 intention on using it lol
    - Diesel's Youtube
    - Diesel's Fleet
  6. #36
    Jul 2010
    544
    It's just funny to look at, you can bend the blades by touching them, not even pushing too hard...
    it should probably just go straight to the thrash.
  7. #37
    4,204
    Just bought a CC1717 for this bad boy. Went a complete different route lol.
    - Diesel's Youtube
    - Diesel's Fleet
  8. #38
    Nov 2008
    Ql
    3,169
    I had the same thoughts about those props too. Sat in the prop box for ages.
    But then, as a challenge I decided to set up a 25"hull to run 6 minute heats on 1 x 5000mah pack like they do in Europe & Hong Kong.
    I tried many props on the 1800kv outrunner in the boat. All pulled the battery down too low before the 6 minutes were up. That prop, however, was just as fast & left enough in the pack to be acceptable.
    13% was the average, with a peak current draw of 47A during the 6 minutes.
    Surprised the hell out of me.
    Haven't had any trouble with it bending.
    I only say this because you may find a future use for it. You never know.
    It's really a heavily de-tongued & back cut prop.
    Cheers.
    Paul.
  9. #39
    4,204
    Cheers.
    Paul.
    I got one with a different HK boat. I used it as a practice prop for sharpening and balancing come out really nice, just never planned on using it lol. I think OSE might sell them. I will S&B this one as well, once again not sure if I will actually use it. If you say they work maybe interesting to try.
    - Diesel's Youtube
    - Diesel's Fleet
  10. #40
    Apr 2010
    3,480
    Me Too!!!
    Pete Z made a very cool mount for me.
    Planning to run a swordy 200 on 6s2p
    FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.
  11. #41
    4,204
    Quote Originally Posted by FighterCat57 View Post
    Me Too!!!
    Those rails are sick.. May I ask where you got them from?
    I plan on running 5s2p & 6s2p and I would like to pick up one of the new CC ice speedo's. I do have a swordy 200 laying around also though.
    - Diesel's Youtube
    - Diesel's Fleet
  12. #42
    Apr 2010
    3,480
    Pete Z did these.
    I'm having some new ones made that have the name actually cut out of the metal.
    Cool stuff.
  13. #43
    4,204
    Pete Z did these.
    Cool stuff.
    They came out amazing! Once i get my motor, I will figure something out. I may have to talk to Pete
    - Diesel's Youtube
    - Diesel's Fleet
  14. #44
    Sep 2009
    ME
    1,332
    holy ^@%@$@@* those rails are the sickest....
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
  15. #45
    Apr 2010
    3,480
    Are you going to do a carbon fiber layup? The hull seems a bit weak to me.
    I've managed to avoid doing them up until now, but think this hull needs some help.
    I may have an extra set or two of those stringers made soon.
  16. #46
    4,204
    Yea it's going to be a must to re-inforce the hull. I been tossing around the idea of going cf, but I have so much fg laying around the shop I may just use up the rest of my supply i have on it.
    Ordered a .187 3/16 flexshaft today & a x450/3 prop.
    I LOVE your motor mount and rails. I just don't have the $$$ for them. I may end up making a mount myself out of alumnium. Between the esc i want for this hull and the aq cat coming soon I am soon to be broke... Need to save where I can which is another reason I may go the FG route since I already have it.
    - Diesel's Youtube
    - Diesel's Fleet
  17. #47
    Jul 2010
    544
    This is particularly awful, at least the one I have.
    I was interested in the shape as well when I got my Pursuit, since it came with a similar one, but the metal quality of the Vanquish one seems WAY lower.
    Just my impression, maybe I got a bad sample.
    Hey FC, you always have the coolest gizmos, I already told ya I hate you, right?
    Cheers.
    Paul.
  18. #48
    4,204
    So I repositioned the trim tabs and I ran into a problem. I had to enlongate the stock mounting holes on the transom to allow the trim tabs to slide up. The left side went fine and I went for the 1mm gap as suggested by 785boats, then the right side I ran into the problem. I enlongated the holes like the left side moved them up and then the top of the trim tab started hitting the bottom of the rudder bracket. I had to grind the the bracket at a angle making sure I didn't weaken the bracket. It came out ok but I was not able to get a 1mm gap I had to go flush with the bottom of the hull on the right side so then I had to lower the left side flush as well. It is a tons better then the stock position though. I will say the hardware is very nice!
    I also was going to change the bushing out on the strut. The end bushing popped out really easy and I went for the aero-marine .187 bushings I always use on the HK/China boats to convert them to 3/16 shaft and the freaking stock bushing is bigger ID then my aero-marine bushing, I never seen that before. I will check if it will works on a 3/16 shaft without changing the stock bushing. When I get my flex from OSE I will check. Maybe a good deal, but if it doesn't work I will just changed the bushing.
    - Diesel's Youtube
    - Diesel's Fleet
  19. #49
    4,204
    Stock on the left, new position on the right.
    *Maybe a bad angle on the right pic. But it is flush with a straight edge.
    - Diesel's Youtube
    - Diesel's Fleet
  20. #50
    4,204
    Just put a CC ice 240 on backorder at tower. No rush for this hull, so I don't mind waiting.
    - Diesel's Youtube
    - Diesel's Fleet
  21. #51
    Feb 2011
    qc
    9
    fighterCat
    wow, thats one hell of a nice motor mount you got there
  22. #52
    Oct 2008
    9,488
    Me Too!!!
    Wow, that is bad azz!
    love the rails
  23. #53
    Jan 2011
    SA
    6
    Default Setup questions, prop etc
    Hi all,
    I'm relatively new to rc boats but the Vanquish is my third and so I know a few things now. However, I need some help in terms of how I set this one up. I had a Pursuit and fitted that with a Leopard 4074/2150 and it ran very well (on 5S). I have since sold the Pursuit and bought this Vanquish and I fitted a 4082/1600 to it, with a Turnigy 180 Esc and 5S. I used the stock prop that came with it, which looked pretty ordinary, even to a newbie like me. Anyway, I ran it and it ran really wet and would suddenly 'fall over' on one side and veer off course. I raised the stinger to its maximum, moved the lipos to the rear, and it ran slightly less wet but still not good.
    I think I have the COG correct but I'm not certain on that, I thought moving the batteries to the back would help more than it has. My questions are, what size prop would anyone recommend for this boat with this motor etc, and, where does everyone mount their batteries ? I want to get the prop that will work and save having to buy half a dozen until I find one that works OK.
    Finally, is it the case that a lower kv motor will turn a bigger prop, and could this be the problem ?
    Thanks in advance
  24. #54
    4,204
    Quote Originally Posted by Ausboat View Post
    Hi all,
    Thanks in advance
    Try a different prop and did you check the location of the trim tabs. If they hang below the hull like mine did that would cause your boat to run really wet as well.
    - Diesel's Youtube
    - Diesel's Fleet
  25. #55
    4,204
    OK so I got my motor in today. It's a Cc1717
    - Diesel's Youtube
    - Diesel's Fleet
  26. #56
    Jan 2011
    SA
    6
    Hi,
    thanks for that ...... yes, looks like I have to move the trim tabs
    What prop would you suggest would be good for that motor ? Is a 445 suitable or should it be bigger ?
  27. #57
    Apr 2010
    3,480
    Yummy.
    Have you thought about prop size?
    I'm guessing that starting with a 1717 on 6s w/x447 is right about on the mark.
  28. #58
    4,204
    Yummy.
    I have a x447, x447/3 and a x450/3. Make a wake is having fun in his 40"+ hull on a 1717 with a x450/3 i think hes hitting 60mph
    - Diesel's Youtube
    - Diesel's Fleet
  29. #59
    Apr 2010
    3,480
    Nice! I'm getting psyched about this build!
  30. #60
    4,204
    Hi,
    445 good place to start, a x447 may work good as well. Start with the x445 check temps if all is well you could try to move up
    - Diesel's Youtube
    - Diesel's Fleet
