Results 1 to 2 of 2
Thread: props
    Feb 2011
    fl
    162
    Default props
    I have 2 prop and wanted to be sure 6017/3 r and one is 6017/3 L the L go's on the left and the R on the right? correct??
    How can you tell if they are not marked?
    Also the flex cable should be right turing for the 6017/3 r prop.
    Dec 2010
    3,119
    Quote Originally Posted by jjrctech View Post
    For better handling the props should rotate to the outside so the right hand shaft and prop go on the right side/ starboard looking at the back of the boat
