I have a question for you. The hardware you used is the same I'm ordering for my project and it says to use .094 cable but all I can find is .098. I see you used .098 was there any issues with that?
Be careful with these guys. http://feedback.ebay.com/ws/eBayISAP...tems=25&page=2
I ordered a few things from them in the past.
Got the wrong Feigao motor (20XL) and they said that it would cost me more to get the motor I paid for originally (9L). Took almost three months to get a rudder from them and it was the wrong one. Wouldn't take it back. Wouldn't answer emails. I was told that they were pulled from ebay for awhile because of their bad customer service. Part of the learning curve when getting into this hobby. Bad Vendors. You might have better luck.
The same thing happened to my Mini-V (not this Mini-Cat) when I did this to her also, she cracked like yours. She also had a serious issue with torque roll. Being a V hull, she had no left / right stability against the torque. This Mini-Cat, on the other hand, does. It's twin hulls will give her much more stability in defense of the torque than a V hull. Also, she's 14.5" long, only 1.5" shorter than that hydro you want to try. That hydro looks sweet, if you can find a US supplier for one.
The .098 had no issues. You will have to shim the strut if you go with a 1/8 stub (prop) shaft. If you stick with the 3mm shaft, your prop choice will be limited.
...Oh, If you only did the flex shaft mod to your V and left the stock steerable outdrive installed, that also adds to your instability with your V. You hear how the steerable outdrives handle like an 18 wheeler? well imagine a twin turbine 18 wheeler.
Do you really think it will kill the handling? Im really eager to do this but dont want to rob a bank to pay for all these parts I need. If I buy all the parts you mentioned on the first page minus the Mini Hydro hardware and I cut the shaft to fit the stock outdrive run it a few times and figure out that handling is crap and decide to shell out the money to get the Mini Hydro outdrive will my cable still fit or will I need a New one?
thanks
The steerable outdrive modded with the .098 flex shaft alone will not "kill" the handling.
It's that mod, coupled with overpowering the boat with a brushless motor that will do it.
where the vid of this thing running????? the wait is killing me
She should be getting wet on Saturday 2/2/08!
A vid of this is like the Loch Ness Monster,,,,there are rumours, but no-one can actually claim to have evidence yet
Grand River Marine Modellers
I'll alert the media.. .. Just kidding. I just wanted to say that. It's all Dudley Moore's fault!
For reference for the youngsters, Dudley Moore was the star of the movie "Arthur".
Ya think we'll get a gps reading too?
any early predictions as to how fast it will be???
The mod won't hurt the handling (if anything it will help) but he's saying with all the power of BL the upgraded hardware will handle much better then the stock stearable outdrive. But if you are going brushless it's a must to at least do the .098 cable drive because the stock streight drive with the plastic u-joints won't hold up and will cause lots of vibration and resistance causing unwanted heat. So just do theflex drive conversion and you can allways switch the hardware out later. Even if your going to do just run the stock motor the flex is a good upgrade. Some run the upgrade and a 3s lipo which gives great speed.
I will predict....31.625 mph against the wind. 34.950 with the wind.
If ladies in bikini's present 33.5 then into the wall!!
My real guess is 24-28 mph.
I like the bikini / wall scenario
i predict its gonna be on my shelf Sun 2/3/08
My guess is that it'll try to leap out of the water, but I will not goose the throttle like last time. 32MPH is my estimate.
Here's what I have as far as a forecast
What? No 70's or 80's? Like I said, Cold. You don't want Dirty to catch a cold running that cat, do ya?
Dirty is gonna put his renegade against the cat. He was supposed to put the arrow wind against it.
today looks good...
snort pixi sticks=symptoms-:
