Looks like torque roll causing this?
The other day I thought I had the boat nearly dialed in.and ran the 58.9MPH with little chine walk issue. though a little lift on the starboard side was the trick.
I ran the thing again yesterday and it was chine walking and I think that was also keeping me from reaching max speed because it only pulled 56mph.
Only difference I can tell is the water conditions are playing a roll. The day it ran 58.9mph the water had a little chop to it. and yesterday at 56mph the water was pretty smooth. Im thinking is it possible that the water conditions helped it with not chine walking?
I tried adjusting the right starboard trim tab and it helped but didn't take it out.
After I got home and watched the videos it seems to be when the boat is spooling up rpms that it leans a little to the right starboard side. Then comes up on plane and then the chine walking starts. I cant seem to trim that out with the tabs. So I am thinking I will try shifting the weight a little more inside the hull. I already have been making it about 5oz heavier on the left port side placing my gps there. Now I had the idea to shift the batteries over just slightly but still in their trays. Just on their sides. I checked this in the bath tub to see if the weight does in fact make the boat a little heavier on the left port and it does. I just hope it helps counter the boat wanting to lean right.
any ideas or thoughts, something maybe I haven't thought of yet is welcome to be brought to the table. thanks,
justin
Pic of what I just thought of trying.
