Results 1 to 5 of 5
Thread: SeaKing 180 timming MG motor
    Jan 2011
    OK
    375
    Default SeaKing 180 timming MG motor
    What should I set the timming to with my Miss Geico stock motor?
    538
    4 pole motor between 10 and 15 degrees
    Jan 2011
    OK
    375
    I thought the Miss Geico stock motor was a 6 pole?
    538
    Quote Originally Posted by pyroM!KE View Post
    My bad, you are correct. Generally, 6 pole timing is between 10 - 20 degrees, but it all depends on prop and how the boat is run. Start with 10, run and check the speed and temps, then try 15 and do the same. Watch it real close with 20. IMO the best will be between 10 and 15. Let us know what you find.
    Jan 2011
    OK
    375
    Thanks for the help..Im charging my batts right now to go to the pond..Damn its windy today!
