I got my MHZ Mini Antenna today, and I'm wondering how to connect my Futaba 2.4g antenna to it. It's got that little slot, but what do you use to keep it on there?
SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
Anyone?
This is not intended to be used with a 2.4G radio. The inductive wire coil allows shorter antenna length for 27~75MHz radios.
Oh wow really? That kinda sucks as I was looking forward to using it. I don't wanna leave the antenna inside the boat, so I guess the only way to do it would be a plastic tube with the antenna sticking out.
Do not use that antenna with a 2.4 ghz system and yes get your antenna outside the hull if you have carbon fibre and also with other hull materials , it may be prudent.
Douggie
Yeah I didn't wanna leave it inside the hull so I thought this would be a good solution. Guess not though. I'm gonna have to find a way to make it look nice and clean.
