Uhu Por contact adhesive, I have used it and Uhu StyroPor (same thing but they dropped styro from the name years ago) on several wood over foam boats with blue, pink and yellow foam, and have used it on white foam flotation, it doesn't soak into wood like epoxy or cynao and much of the weight evaporates off but unlike most contact adhesives the solvent is foam safe.
I have also used copydex contact adhesive in the past which I think is latex based, but Uhu Por bonds better and is lighter.
Or you can make an epoxy glued balsa skin much lighter by applying a coat of cellulose dope sanding the balsa and recoating with dope, which weighs virtually nothing once it evaporates but stops the balsa absorbing the epoxy, which is a large proportion of the weight. DON'T try to do it to the foam too though as the solvent in dope is definitely NOT foam safe.
