Here's a simple way to add water cooling to an existing aircraft ESC.
I have a $50 Hextronic Pro 120A ESC, rated for 120Amps. To convert it for a marine use, I first removed the label and heat shrink material on the back and front plates and then bolted on the Aquacraft Cooling Jackets that are made for the SV27. I used 3mm x 1inch long HEX screws to sandwich the ESC. To use it with a pistol grip radio, I'll be using an inline Pistix adapter.
Parts Used:
(4) 3mmx1inch long hex screws
Aquacraft Cooling Jackets = $14.49 @OSE
Rc Hydros Pistix Adapter = $13.50 @OSE
By the way, does anyone know where you can find a very small computer fan (1.5" to 2" diameter) to place over a OEMRC 100A ESC?
