Page 2 of 2 FirstFirst 12
Results 31 to 50 of 50
Thread: Need boat !
  1. #31
    190
    I have an echo and love it, the fact that it turns on a dime at full speed is hard to beat!!!
  2. #32
    Jan 2011
    AB
    21
    Quote Originally Posted by badag98 View Post
    Do you run yours on 2cell or 3cell Lipo ? Was your MiniEco self righting out of the box or did you have to tweak it ? If so what did you have to do ?
  3. #33
    Mar 2007
    VA
    7,212
    I ran mine on 3S, yes it self rights out of the box (it has a flood chamber). Stock vs. Stock, I'd say the eco is faster.
    Nothing turns like an eco!
  4. #34
    Jan 2011
    AB
    21
    Quote Originally Posted by Diegoboy View Post
    Will changing the prop or batterys have an effect on top speed or is the stock configeration pretty much as good as it gets for speed with out changing motor ?
  5. #35
    Mar 2007
    VA
    7,212
    You can change the motor, but it's stock motor is all that this hull needs on 3s. If you run 2S, you can change the motor to get more speed.
  6. #36
    190
    I run my echo on 3s, and had to add a couple extra holes too the flood chamber plus some lead weights on that side as well.
    As for upgrades, I'm not sure you could use a much bigger prop due to clearance issues. The stock motor is fast on lipos
  7. #37
    Nov 2007
    6,927
    watch the videos. They are totally different in how they drive. The esc's are irrelevant as they work with the motors installed. The carbon props work great on the mono. The reason for the stainless prop on the ECO is because it is tiny. Carbon would never hold up in such a small size.
    Mini Cat Racing USA
    www.minicatracingusa.com
  8. #38
    190
    Well if your not going to buy my micro cat I have listed.....lol
    My vote would be the Mini Echo, its a pond rocket that makes 90 degree turns. Of the boats I have it is by far my favorite. It is fast and turns on a dime plus you will not have to go swimming like I have after my SV!!
    Good Luck
  9. #39
    Aug 2010
    uk
    2,887
    As Sailr has said their very different types of boats, The Velocity is a surface drive deep v that rides very well in chop ( relative to its size ) & i would say is probably faster in a straight line. The Mini Eco is a mono that is still used at world championship level & is sub surface drive & will turn much faster ( blink & youll miss it ) but needs less chop than the Velocity. Very difficult to pick one over the other. Thanks Martin
  10. #40
    Oct 2007
    1,302
    So you are not considering the Starship anymore? It's the fastest of the bunch.
  11. #41
    Aug 2010
    uk
    2,887
    SweetAccord for my own interest how stable do you find the Tenshock minicat & do shafts last ok in them, Also considering the Hor Bolt Micro but dont know much about them though. Thanks Martin.
  12. #42
    Oct 2007
    1,302
    I have not replaced the shafts and they last a long time being a wire. I do run the liner in mine and oil it after every two runs. The Minicats are stable no real issues, or quality issues. I'm still waiting on my Bolt to say how I will like. It's a copy of the Minicat Hydro but the drive line it larger and the motor coupling is larger. Overall there is not a HUGE difference. Just minor ones but I have not done a 1:1 comparison yet. I do prefer the looks of the Minicat.
  13. #43
    Oct 2007
    1,302
    Martin, get with these guys on the Hor as they have run them. https://forums.offshoreelectrics.com/...ad.php?t=21402 You can see how the Bolt runs on youtube. Hobby King carries it also and I believe there is a review of it on youtube also.
    Hope that helps.
  14. #44
    Aug 2010
    uk
    2,887
    Quote Originally Posted by SweetAccord View Post
    Is the wire drive you have in the Minicat an after market one that you fitted as i thought they came with flex shafts as standard, Or am i mistaken. Thanks Martin.
  15. #45
    Oct 2007
    1,302
    You are correct. It's the flexdrive that is how it comes and I am using the original one. I call them the a wire drive and that is my bad. To me they are both a "wire" but that is incorrect thinking.
  16. #46
    Aug 2010
    uk
    2,887
    Do you find that the Minicat flips very often & what sort of water does it like. Thanks Martin.
  17. #47
    Oct 2007
    1,302
    Both like calm water but a little chop is ok, and I have yet to flip either one, but then I baby my boats and don't do full throttle turns on purpose even on calm water.
    If you go to youtube and search these boats you can see how well they run if you observe the water in the video. We don't get much wind here and the water is mostly calm.
    Here is a short video of mine (starship):
    http://www.youtube.com/watch?v=YoPuUuX2hk8
  18. #48
    Oct 2007
    1,302
    Ok I've done all the homework for you on the Starship. All you have to do is click and watch. You can read all the users descriptions on their setups (if posted) and see how they are modding these with different motors and what batteries are being used etc.
    Also you can see how they perform in different water conditions also and get a good idea what to expect.
    Click, watch, enjoy:
    http://www.youtube.com/watch?v=Y_c6_mwzB9E
    http://www.youtube.com/watch?v=eZJjAcYjrRY
    http://www.youtube.com/watch?v=k36dQ7KoTzw
    http://www.youtube.com/watch?v=lr-8FcELANY
    http://www.youtube.com/watch?v=rbaVC3vukBs
    http://www.youtube.com/watch?v=jCqXReHnBbg
    http://www.youtube.com/watch?v=e2U-DiiqyJw
    http://www.youtube.com/watch?v=xj_31b-l6-c
    http://www.youtube.com/watch?v=GZ7pBEoJ-44
    http://www.youtube.com/watch?v=RTHSG_2qhic
    http://www.youtube.com/watch?v=5k-jNZVEQYM
    http://www.youtube.com/watch?v=UXU0uavNgLY
    http://www.youtube.com/watch?v=bC7Wk2A9MJc
    My favorite video showing what this hull can do being so small: http://www.youtube.com/watch?v=dG571aBymKs
    Running in rough water: http://www.youtube.com/watch?v=fk5pFWA_CJE
    Funny: http://www.youtube.com/watch?v=QKBLp3UsXPo
    Tenshocks Catalog: http://cid-ace3bbbe72a55299.office.l...g/Tenshock.pdf
    Hope that helps.
  19. #49
    Feb 2011
    Xenon project. Com has tear into nqd's jet boats for 38 bucks
  20. #50
    Oct 2007
    1,302
    Quote Originally Posted by ms7497 View Post
    Lots of those boats are plastic toys. They don't really compare to what we are running here on OSE.
