Results 1 to 5 of 5
Thread: Is an Octura 1740/3 a good prop for....
    Jun 2009
    1,177
    Default Is an Octura 1740/3 a good prop for....
    a 25" Maus/Bandit shovel running on 4S,Ammo 2300,MissGeico/proboat esc?......does it has the right lift for it or is it overkill?....thanks,...Al
    Dec 2010
    3,118
    Quote Originally Posted by Karfrik View Post
    1700 series are good for outboard riggers try it and see good luck !!
    Oct 2007
    Fl
    182
    To expound on what dasboata said the 17 series are about the highest lift props Octura makes. The reason they work so well on O/B hydros. You may need to do some mods to the prop to make it work on a sport hydro and/or use a very high strut setting to compensate. We use to run 17 series a lot in oval riggers and they performed really well. Because of the blade progression they are very effecient but they do require a little different setup than lower lift props.
    Chris
    Jun 2009
    1,177
    thanks guys,...anyone more suggestions on this prop?.....bump!!!
    Va
    4,670
    I run a Prather 215 in my Campbell Vintage shovel on the same motor.
    IMPBA 20481S D-12
