Hi guys again bothering you.
Can you tell me if this motor works in my spartan boat?
whats going to be the speed with 6S and a metal prop?
http://articulo.mercadolibre.com.ar/...o-por-agua-_JM
Thank you
Thank you
No 6S with that one, way too high KV....
And WAAAAAY to small to add to to high kv. The 39mm Dia is including the water jacket incorperated in the motor it's really like a 36x50mm motor. Grab a Leopard 36x74 1300kv on 6s
The price is 150 us? way too expensive!!!!
The pursuit has a 3660 2760kv fsd.
www.fsd-motor.com
for $180 you can buy a pursuit
i can't find for 180 the pursuit.
here ya go. The 1450kv for 6s: http://www.offshoreelectrics.com/pro...o-4082&cat=148
The kv is ok for 3s.
What do you want to do with it?
I run my 33' mono with a leopard 4074 1400kv on 5s 45 prop.
Here is with 8s http://www.youtube.com/watch?v=0k8cdxFYLZ8
3s, on a 36" boat? No. Look at the first post. He wants to run 6s. FSD motors are junk, too.
http://hobbycity.com/hobbyking/store...dProduct=11853
You have to be a Platnuim member and the price changes from $437 to $179 when you place it in your cart
I am.But on the foto says 179.99 and after says 437
o yes i just order it
thanks for the replys
The price is in ARGENTINIAN PESOS. Its like 60 dollars. Im from Argentina.
I guess that LEOPARD 4082 1450 would be best option to buy or something similar to this one.
I want to run the spartan boat on 6S and be about 50mps with the correct proper and water pickup setup.
Thank you very much
its a abs hull i guess. Dont know what is ABS, but definetely its not fiberglas.
Its just a plastic hull
thx
