Results 1 to 14 of 14
Thread: Turnigy 120A Marine ESC programming
    May 2009
    535
    Default Turnigy 120A Marine ESC programming
    Does anyone have a pdf of the programming instructions for the Turnigy Marine 120A ESC?
    There is nothing on the HobbyKing website in the "files" section for this ESC.
    Mar 2007
    VA
    7,212
    Try HERE.
    I use THIS one.
    May 2009
    535
    I believe that the SeaKing card is the correct one for the Turnigy Marine Series. The other pdf is for the HiFei Swordfish/Aquastar(Turnigy) Series.
    Thanks!
    Aug 2010
    AT
    568
    I have the turnigy 180a with the hobbbywing prog card and works perfect.
    Same company with other name
    Dec 2010
    3
    Default Timing???
    I just got a Turnigy Seaking ESC and I am going to use it in a ProBoat Miss Geico with a ProBoat 1800kv motor. I need to know what to set the timing at, it comes with a default set at 15 degrees. Is this right, to high or to low?
    Almost forgot, will be running 4s2p 4000mah lipos.
    Thanks!
    Aug 2009
    tx
    3,534
    geico motor is a 1500kv i believe
    Dec 2010
    3
    Quote Originally Posted by Alexgar View Post
    Yes it is, but I am going to use the 1800kv motor with the 120A ESC.
    Aug 2009
    tx
    3,534
    thats probably the right timing
    Dec 2010
    3
    thanks for your reply but to be on the safe side I think I will start at 7.5* and work my way up.
    Dec 2010
    ks
    403
    let me get this straight ....the turnigy esc thats 120 amp can be programmed with the seaking card?....or am i spazzing here?
    Dec 2010
    ks
    403
    I just installed a turnigy 120 amp in me geico so im curious also
    4,204
    Quote Originally Posted by dano1 View Post
    YES, but only if it is the Turnigy marine series esc's. The marine series ecs's are all Seaking esc's. The turnigy aquastar esc's are Hifei swordfishs, the same esc's steve sells. HK doens't make anything, they rebrand.
    - Diesel's Youtube
    - Diesel's Fleet
    Dec 2010
    ks
    403
    oh sweet news...im not sure where this esc is set at and seems to be used as a single unit not in serie, only had one wires to dean connector that i chucked and i set it up in series but havent got to test it any.....snowing here now....gonna be a long wait here.
    Thanks again diesel
    Jul 2010
    14
    412
    It's a breeze to do it with the card.
    http://www.youtube.com/watch?v=act-jrhOZ4Q
