Hull=32 cat from fightercat57
hardaware=TFL+H&M
Motor=LEHNER 1950/5 and MEDUSA 36/70/2300KV @4S and 5S.
ESC=HIFEI 120A
carbon-aramid reinforcement
easy access water lines
MINI COOPER......
hardaware=TFL+H&M
ESC=HIFEI 120A
MINI COOPER......
H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
Not to be insultive,but whats with the carbon on the hatch?Looks like it was just thrown in.Why not make it go to the edges and cover the entire hatch?Again,Im not trying or meaning to offend you.Just curious.
i wanted a reinforcement without cover all the hatch.only the top of hatch.im going to use tactic,so no antenna outside.for good signal trasmission without blocking from carbon-aramid.
sorry for my english...
I will be surprised if your tactic works inside that CF coated hull. Looks good, but as I understand it, you need line of sight with your receiver and since the CF wraps up to the top of the hull, you are pretty much encasing the receiver in it.
"Look good doin' it"
See the fleet
Is there carbon on the underside of the rear deck? If not, that could be your out. Just a thought. I run 2.4 fully incased in a HPR w/ no problems at all. Ive not experimented w/ tactic, but the futaba 2.4 does work inside.
