i am having trouble getting my hyperion 1201 charger to want to charge these batteries.any suggestions?
What kind of trouble is it giving you...your description is really vauge.
Grand River Marine Modellers
doby:i tried to send you a rather lengthy reply explaining problem however when i submitted it it aparently got lost. what happens is i have to use one partictular pack to trick charger into charging any of the other packs.i am using a astro blinky to balance the packs & always discharge them down to 3.0v & recharge them to 50% after testing.any ideas?
When I charge my batteries I plug my battery to red and black port on the charger along with the balancing port, set to lipo, capacity, charging rate and up he goes....
I charge my batteries fully unless they have to go on the shelf for a while than I will use STORAGE function on my charger. Not sure why you need to trick your charger. ( maybe it is time for new one )
Down to 3V and back to only 50%, why? What testing? What do you mean?
DJI Drone Pilot
Canada
ive donethat you probably have a bad cell check then with a meter through the bal lead , if your making a bad cell charge it could be dangerous, ive bought 2 venon and havent had great luck with them
i have tried twice now to send a more detailed reply about this problem,however when i do it gets erased when i hit reply.
i have tried twice to send detaild reply about my charging problem,however when i try to send it says i don't have permission.if anyone has any suggestions on my charging problem feel free to contact me at williamamick@clear.net
mystery solved.bad battery lead connector,
