Here are a few shots of my new BJ26 with fullers catamaran hardware and other simple modifications!:D This set-up ran much better than the stock out of box. No gps yet but I would est. speeds of 40-45mph. I am running on 2S2P 4350mAh Polyquest lipo's.. And for max. run time I use 4S2P 3700mAh Polyquest lipo's!!
1. Fullers Cat Hardware w/ .150 f/cable and 3/16 to 1/8 prop shaft
2. Remove spin fins and drain plug, (filled holes)
3. Moved Ant. mount to the rear
4. Removed radio box, but reused the wood servo tray (put tray in place of radio box, had to make new linkage for rudder)
5. ESC was moved to center in front of the motor, power wires shortened (mounted w/velcro)
6. Receiver moved and coated with (3M DP270 epoxy)
7. Hatch (filled in hole where ant. came through)
8. Use OSE tape for the hatch to keep water out
9. Prather 220 prop (balanced & polished)
All these mod's helped with turning, stability, smoother driveline, and helps keep the water out!
I had fun testing this boat in stock form, it did well. Now it just performs GREAT, and after 5 min of running hard, esc and motor temps were below 90 deg. and 100 deg. on the batteries!! I will keep it around for a while!!!!
