Results 1 to 9 of 9
Thread: seaking 180 on 6S power
Hybrid View
    Jan 2010
    VA
    1,218
    Default seaking 180 on 6S power
    OK folks, there are those of you that have/are running the Seaking/Turnegy 180A
    Marine ESC on 6S power with a stand alone/BEC receiver power.
    Please if you would speak up and let others know what your set-ups are so that other folks can get some information on what is good and not so good. (if you will)
    Hull:
    Motors: to include manufacturer, kv, amp rating, ect
    Props:
    Battery Mfg. and Amp/C rating
    Thanks everyone for your info.
    Aug 2007
    AT
    1,072
    I run the mean machine on 5-6s
    Hull: Mean Machine
    Motors: Turnigy T600 1400kv, Scorpion 4025 1480kv
    Props: 445 on 6s, 646/3 on 5s
    Battery: 6s1p Turnigy 5000mah 40c
    5s2p Turnigy nano 4000mah 25-50c
    I also use the T180s in my Maritimo and twin sprintcat but on 5s with hpi 2200kv motors and 442 props
    http://www.rcfastboats.com/
    Dec 2008
    Vi
    409
    I run a DF33 on 6s with the T180 ( BEC disconnected ) , 4082/1500kv leopard motor , x646 & X648 props , Hyperion 35c-6500mah 3s lipo packs, for a cheap ESC it has held up well , for the last 4 months i have been running it , the only problem i have had was the LVC was cutting in way to early ...
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
    Nov 2009
    US
    5,557
    45" Dumas Scarab
    T180
    Neu 1527 1Y 1250kv
    6s2p Zippy 6s 4000 40c x 2
    Octura x447
    Using internal bec
    39" Mono
    T180 (added two caps)
    Castle 1717 1580kv
    6s2p 4 x 5000mah turnigy 3s 40c's
    X645(was using x447)
    Using internall bec
    Folks are hitting the LVC with the T180 prematurely, but the last guy found out it was due to running 1p..............thats usually the case........happened to me in my Dumas til i went 2p.
    NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE: https://forums.offshoreelectrics.com/...est!&highlight=
    Nov 2009
    Ca
    2,686
    40" mono
    Leopard 5692(1340)
    T-180
    4-turnigy3600mah/3s/30c/=216A on 6S
    internal bec
    X-452
    Oct 2010
    752
    54" Bonzi Sports Fountain
    Twin Leopard 5692 motors
    Twin Sea King 180s
    Four Turnigy 5000 mAh 40C 6s
    Jan 2010
    VA
    1,218
    Great guys!!!!!!!!!!!
    keep the info coming so everyone can see how it all shapes up for the ESC and such.
    This is what the forum is all about.
    Jul 2008
    MO
    218
    Delta force 33
    Neu 1515 1.5y
    Turnigy 4.5 3s 30-40c (x2) in series
    M445, x447
    Bec disconnected
    Hpr 115, Neu 1521 1.5d x2. Delta force Pirate, Insane 45" Neu 2230
    Aug 2009
    tx
    3,534
    fastech
    cc1515
    t180 on 6s internal bec
    turnigy 6s 5000 30c
