Dead birds dropping from the sky, land being flooded, -20 and 60cm of fresh snow here, so I thought it’s time to think about a new boat before this planet capsize
I got a used surge crusher last august ,and even though the season allready was going towards the end I managed to get many trips and some upgrading done to.
Prather 215 prop and 180 esc + typhoon 500 motor.
http://www.youtube.com/watch?v=F7wMY_t6cL8
now I want a geico, so I could use a litle shopping help.
I have 2x 3s packs and 4x 2s nano packs,all 4000. A junsi 308 charger and
a 180 amp ecs.
It will be running on 4s and 5s , and maybe (well 100% sure) 6s when i change the ecs.
I need suggestion on props for both 4/5 and 6s running.
My shopping list so far:
Pro Boat’s fully licensed Miss Geico :
329.99
Now includes a corrected Flex Shaft for Free!
Is this the ose shaft ??
ProBoat Miss Geico Radio Box Cover: $3.99
OSE Flex Cable Assembly for the ProBoat Miss Geico : $24.99
Div props:
Octura x442 Sharpened & Balanced : $36.99
Octura x642 Sharpened & Balanced : $36.99
Octura x445 Sharpened & Balanced: $36.99
Sharpened & Balanced GrimRacer 42 x 55 Prop : $44.99
BL ESC Programming Module for PRB3309
Is this nessesary to get he esc up and running in lipo mode? Ore can I use the tx to do the setup ?
Also the rudder hop op, where do I get hold of it ? if different types, what workes the best.
Some tips on bullet connectors as I'm currently using deans, anyone from hobbyking ok ?
And last for now, any engine upgrade worth mention? I like to have a spare lying arround. The typhoon 500 worked well on 4/5s with the 180 amp esc in my SC and it was cheap to.
