Results 1 to 16 of 16
Thread: Prop Diagram
    ma
    8,693
    Default Prop Diagram
    Steven Vaccaro
    Jan 2009
    ca
    842
    Broken tip on the left side?
    ma
    8,693
    I used a new prop, so it wasn't broke. I think it's the way I took the photo.
    Steven Vaccaro
    May 2012
    940
    Great explanation and picture Steve need to be in a Read this first Newbe and yes for everyone.
    May 2012
    940
    Steven,
    Here is a copy of the latest Octura information sheet 9.2012 listing the Prop number, Diameter and then Pitch.
    Makes it easier for me to follow and then make a decision on which ones to order.
    Mike
    ma
    8,693
    can you email it to me or try to attach it again?
    Steven Vaccaro
    May 2012
    940
    Default Octura New Prop list 9.12
    Here you go Steven
    Nov 2016
    44
    Trying to find where to buy a b/s x440/3 I think it is a stainless steel for my Miss Geico 29 v3 all stock
    ma
    8,693
    I just sent you a pm.
    Steven Vaccaro
    Nov 2016
    44
    Default Miss Geico 29 v3
    I just received two Octura X440/3 props and both of them seem to have the same problem, they will not fit the drive dog.
    it seems that one side of the slotted end of the prop is misaligned and if I removed about 1/16" from one side on the leading edge it would fit, but would be out of balance. what would you recommend.
    ma
    8,693
    Quote Originally Posted by Fixitguy1 View Post
    Do you happen to have a picture? Sometimes the slots have to be opened.
    Steven Vaccaro
    Sep 2012
    Tg
    1,439
    Use a 5/16" (8mm) od drive dog.
    9,398
    Yep use the little doggy.
    Removing material from the hub has less of an effect on practical balance than you may think. Removing 1/16" from the slot sounds like way too much however...
    Nov 2016
    44
    The drive dog slots are fine the tongue material is covering the the drive dog slot on one only
    Nov 2016
    44
    Hope you can see this.
