Results 1 to 7 of 7
Thread: seaking 180 timing
    Dec 2010
    WA
    107
    Default seaking 180 timing
    guys the defult setting for the seaking 180 esc timing is 15.00 is this ok with 4s in a cat with 2100kv ? ,as i know in my cars the timing is always very low or 0 or your temps are thru the roof ,,please explain ??
    Nov 2007
    6,927
    What MOTOR? Feigao? Neu? Leopard? etc? That is what determines where you want the timing set.
    Mini Cat Racing USA
    www.minicatracingusa.com
    Dec 2010
    WA
    107
    feigao 2073 kv
    Aug 2010
    17
    I'm also interested to know. I have a Neu 1515 1Y. I've run it at 18* and 22* but it doesn't seem to be any faster than at 15*. But the run times are shorter and temps are MUCH warmer with the higher advance settings. Thanks.
    4,204
    Quote Originally Posted by Gen View Post
    feigao 2073 kv
    Try 7.5*
    Quote Originally Posted by 57burb View Post
    I would keep at 15*
    - Diesel's Youtube
    - Diesel's Fleet
    Nov 2007
    6,927
    I would run that motor around 10-12 degrees.
    feigao 2073 kv
    Mini Cat Racing USA
    Nov 2007
    6,927
    Too high. Some run that motor at ZERO-5 degrees. 15 degrees is as far as you want to go. The higher the timing, the shorter the runs and the temps go up.
    I run the 1515 1Y at 8-10 degrees
    This is direct from Steve Neu:
    Suggested controller settings when using the CC125 and CC180 controller.
    Set cutoff to 4 volts (option 2)
    Disable current limit (option 5)
    Brake type: Hard brake, no delay (option 4)
    Throttle type: Fixed throttle (option 2)
    Advance: Low advance timing (option 3)
    Cutoff Type: Soft cutoff (option 2)
    Soft Start: Fast start (option 3)
    PWM Switching Rate: 13 kHz (option 1)
    Mini Cat Racing USA
