We start out by mounting a 2200mAh 3S battery on the left (port) side of the boat with the back of the battery about 2" from the inside of the stern. That's a good starting point. Read paragraph 6 in our instructions.
http://minicatracingusa.com/images/i...esinstruct.pdf
You can adjust the battery fore and aft to achieve the best placement for running. For rougher water conditions you can move the battery slightly forward and for calm water, move it back slightly.
The Joysway boat is a copy of our Velocity and does not have the same power level. Proper balance is also affected by the amount of power the motor produces. We run a 32mm prop stock, unlike the 30mm on the Joysway because our motor and esc will take it!
Have fun with your boat! Feel free to call us if you have any other questions. Our "job 1" is customer service!
