Originally Posted by
antslake
Ok, here is how I see it. I am no expert on this, but I do know a lot, but I don't do it frequently enough and I maintain the right to be wrong, lol.
In automotive, and what I've learned from my Tekin dyno, and my medusa research dynos we can measure and compare hp/torque/efficiency of motors if the load is constant. The prop is a constant load (provided the load isn't changing when moving from 1 to 2 props due to placement on the motor mount) I think that affect is nil in the lifting setup you used. You are using 2 props of the same brand and size, but they may not be exactly the same, or are the motors exactly the same. That is why I requested the second motor test, to see if it draws around the same as the first one, which I think it will be very close.
Ok, having said that..we can simply take some numbers from the list you provided. It takes X amount of watts to turn Y amount of rpm's. We can get a number, rpm's per volt (N). Simply divide the rpm's by the watts.
2 motors, 1 ESC:
14000 / (287.3/2) =97.45 rpm's per watt (average for two motors)
1 motor, 1 ESC
14050 / 147= 95.57 rpm's per watt
At a higher rpm (which would be less accurate due to stalled props):
2 motors, 1 ESC
18000/ (539/2)=66.79 RPW
1 motor, 1 ESC
17800 / 274.5= 64.85
You are getting slightly more rpm's per volt with 2 motors. This percentage is almost negligible due to inaccuracies in the test equipment, and possibly using one battery pack, and having different input voltages. Not to mention, motor #2 may be more efficient or the prop may have less drag due to slight imperfections, or balance issues, etc.
What I see is they are even, and work fine under a constant equal load. How about trying one with a much larger prop to simulate a exaggerated uneven load?
I admit, I don't know enough about ESC and exactly how they work to give some better ideas as to why we shouldn't use this in a real setup. I do have a question about ESC's, do they sense rpm's on the poles that are not energized to know when to apply current to the energized poles? Could this be the reason why if one motor is severely loaded up different that the other, you could have major issues? I suspect the efficiency of the 2 motor setup would go down as the loads change. Or, as the load on one motor increases, the sensing part of the ESC will slow both motors down. I realize there are sensor, and sensorless ESC, but I do not know the specific differences.
