It can be done and here are my video test results…http://www.youtube.com/watch?v=zeYAW...=youtube_gdata
There appears to be more and more multiple brushless set ups for FE boats recently. Twins are common but triples and even quad setups are being built and discussed on various OSE threads. Is it possible to run multiple brushless motors on ONE ESC in multiple motor set ups? I did some web research and the general opinion is that:
1. It probably will not work
2. If it does work it works only on small CD ROM-type motors
3. It will damage your motors and ESC’s
4. The back EMF will cause confusion to the motors that they will jitter
5. You will have a very difficult time trying to start BOTH motors together
6. Etc, etc
Here are some of the links I used in my web research…………
RC groups thread……..
http://www.rcuniverse.com/forum/m_4877831/tm.htm
WattFlyer thread…………….
http://www.wattflyer.com/forums/showthread.php?t=9264
Hobby King Forum discussion…………
http://www.hobbyking.com/hobbyking/f....asp?TID=14234
So, being curious and thinking about a real exotic multiple brushless motor build, I decided to run some actual tests with moderate size brushless inrunners and outrunners. I went all the way up to two Leopard 4074’s running on one SeaKing 180 ESC as shown on the video
NOTE: I am not recommending or endorsing the use of a single ESC for multiple motors I just wanted to point out that my experiments proved it was not only possible but actually worked quite well. Naturally in such a configuration the ESC must be matched to the COMBINED AMP DRAW of both brushless motors. Now it’s time for some actual load tests and more experiments!
