Hey guys! I'm new to the forum (in case you haven't guessed ), but I got an Aqua Jet a few days ago, from OSE, with an erratic ESC. At least I'm pretty sure that is the problem, I was breaking the brushes in and all was going fine for a few minutes, then something seemed to snap and I had no throttle control. I could pull my throttle trigger back, just a little as if to go an idle speed, and it would go full throttle no matter how hard I pulled it. So I flipped the switch on the boat OFF, and the 775 motor took off just as fast as it could go. Naturally I had no idea as to what was happening since I figured that the motor should *STOP* with the switch in the OFF position, so I finally had to unplug the batteries to get it to stop running. Anyway, I was just wondering if I should send the ESC back to CEN or is there something I can do to fix it myself?
Any help is appreciated...Thanks! Nice boards BTW....
