Results 1 to 2 of 2
Thread: seaking 120 esc BEC
    Dec 2010
    WA
    107
    Default seaking 120 esc BEC
    i have a seaking 120amp esc and the bec has failed and i want to wire up a new one ,now i think this component pictured is the bec ?? IS IT ?? it is a small electrnic circuit board in the wire from the esc to the reciver ..
    ,and i want to just cut the wires and connect to a new external bec ,the new v2 esc dosent have this attachment in the leads as mine does
    note this did have black heatshrink on too..
    Jan 2010
    VA
    1,218
    could possibly be the BEC.
    just remove it, install a new servo connector, and run a seperate
    battery supply to the receiver.
    just my opinion.
