So try it?
Does it take a little "hotness" off of the setup by reducing the ESC timing back to zero while testing the 645?
No. Do not run at 0 deg. timing. The motor will not like it. It will have little to no effect on the esc performance.
Another good prop that you test is the 447/3 detongued
http://www.rcfastboats.com/
I have a 39" delta force mono running a 1500 kv motor on 6s. All the props I see people throughing out there I tryed and they worked like crap. The boat really woke up when I went to a 452 then a 455 prop. Monos like big props with little pich better.
Mark
Thanks Mark.............gonna order an x450 tonite......the 645 hub is smaller and looks goofy behind the large drivedog anyways.........not a smooth transition.
What size is your motor?? What speeds?
Mine Didn't come alive till the x455. The 452 gave me good runtime, but I was running 9s 10000 mah. The hull needs enough prop diameter to efficiently push it.
I'm running a Neu 2215 1y Thunderpower 6s 5000 X 2 and Castle HV240. Speeds are in the high 60s.
Why would you order an X450? Thats still to small
Mark
That was a cool video and excellent job well done! It’s a pleasure to come to the forum and listen to some very helpful suggestions and comments!! It’s a sure way of improving your boat’s features!! That was the first time I saw such a beauty and thanks for sharing it here!!
Life
Ok...........short vid with the x645
Edited it down to the pass i think got the highest gps reading for time saving
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE: https://forums.offshoreelectrics.com/...est!&highlight=
sweet!
Thanks!
I am very impressed with that motor. Good stuff, man!
Thanks Rum............i really wasnt expecting mid fifties when building it to be honest..............very pleased. Some final tweaking(cog, stinger etc...) may have it hit 57-58................thats pretty darn fast in my book for a 6s, 39" mono
Very nice. I'm looking forward to soft water and trying mine in a cat.
I used one in a Drifter L and it RIPPED!
Mines going into this... the orange one.
Outrunner 1400kv brought it to 50+ mph on big x450 prop, 5S2P 4yr old cells.
Should be great Ray, i bet mid 60's for it!
