Page 1 of 3 123 LastLast
Results 1 to 30 of 62
Thread: Triple Cat
    May 2010
    MO
    3,278
    Default Triple Cat
    I got this Daytona/Genesis hull from FighterCat a while back.I re-inforced it with FG matting and resin.I also sprayed Great Stuff window and door expanding foam in the front for a little more strength and mostly for flotation.
    The 3 motors will be Align 600XL outrunners in 1650kv and most likely X447 props.These will be run on 6s with 120 amp esc's.Im still waiting on the stingers from Ben,so as of right now,Im at a standstill.I will be using .187 flexes,2 left hand and 1 right hand.
    This wont be a speed record setter-Im expecting low to mid 60's with it.Im building this a triple just to have something different.
    2,686
    Uh Oh! Larry is "upping the bar"
    May 2010
    MO
    3,278
    No,no,no..Just wanting something out of the ordinary.I learned alot from my EKOS by not re-inforcing it to begin with,so every hull I get will get it.These motors arent really a "hot" kv for 6s,but it ll run good Im sure.The Prop Shop in the UK has some bigger than 47mm and 50mm twin drive props,so maybe I can move up a bit in diameter without heat and amp loads since there will be 3 motors.
    Oct 2010
    752
    You got my attention my man!! I like it!!!
    Lets stop bending the rules of normalcy, instead lets destroy them! I love seeing out of the ordinary builds. I like doing them too obviously.
    I'm watching.
    US
    5,557
    Nice idea!!! Very cool..............
    Oct 2008
    9,488
    Wow!
    May 2010
    MO
    3,278
    Thanks for the comments.Hopefully,the stingers will be here soon so I can commence building.
    Jul 2010
    3,663
    I bet you hit 70's with that setup when you find the right prop. This thing is going to be a monster Larry. Very cool build
    Jun 2010
    OH
    772
    With it being a triple u might get away with the x450/3! Sweet build!
    May 2010
    MO
    3,278
    Thanks.I hope I can get 70 out if it.Ben says the stingers might be here by Feb.1.Im getting ancy to build it.Still need to by esc's and a couple more batteries and small parts.
    Aug 2008
    7,080
    where's the "all aboard" emoticon?
    I'm in...
    "Look good doin' it"
    See the fleet
    May 2010
    MO
    3,278
    Hope you have a big bag of popcorn Jesse,it ll be little while yet.
    Aug 2009
    tx
    3,534
    you said outrunners right?
    May 2010
    MO
    3,278
    Thats what they are.Theres an "outer"can to them.Thats why you see water jackets on 2 of them.
    Aug 2009
    tx
    3,534
    where did you get them?
    May 2010
    MO
    3,278
    Bought them used in the Swap Shop.I dont know where you can buy them new at.They are Align brand motors-I guess do a search on them.
    Oct 2010
    MO
    194
    Default align
    Those are stock motors for the Align 600 e heli. readyheli.com has them in stock new. The 600L motor is a crap shoot with some of them being not very tolerant to heat. The newer 600M motor almost eliminates that issue and has a longer mean time before failure rating. Ask me how I know. you can find them new and used on runryder.com as well. Some guys buy the kit and sell the motor out of it and go for high end aftermarket motors from Xera, Plett, Neu or Actro. fwiw. Might find them on ebay but stay away from the 600L new on ebay chances are they are the troubled ones that got unloaded. jmo
    Larry c ya at the pond soon!
    May 2010
    MO
    3,278
    That made me paranoid.Maybe they will be fine since theres 3 of them?
    Oct 2010
    MO
    194
    Default no fear
    Remeber they were air cooled only under the canopy of a 7 to 8.5 lb heli with the pilot doing stunts that would destroy a full scale heli running very close to wot. In your application I can't see heat being an issue. I was just sharing nfo.
    May 2010
    MO
    3,278
    Thanks.I checked out readyheli,its a nice site.Was looking at the Scorpion motors too.
    Oct 2008
    9,488
    what about the Castle 1717 air motors that are the TRex 600 replacements?
    Oct 2010
    MO
    194
    Default scorpions
    I've had 6 or 7 scorpions and have yet to own one that I did not like. Got one in each of my helis and plan on putting 2 in my mini cat. You must service the bearings tho. No big deal,,,a drop of oil for every 5 or 6 flights or ceramic bearings.
    They even sound different with the ceramic bearings.
    Oct 2010
    MO
    194
    My wattmeter said the castle was more efficient than the scorpions and slightly more powerful than the align motor but I could bog the castle easier than the scorpion. I had to try hard by doing pitch pumping tic-tocs but the castle was easier to bog on the same pinion and setup.
    May 2010
    MO
    3,278
    Stingers in!!!The build commences!!!
    Oct 2010
    MO
    194
    I'll be checking back often Larry Need anything just holler.
    Apr 2009
    BJ
    251
    That's really different, I like that concept.
    As of the Align 600. Personally I think the benefit using outrunners in boat was the cost. But as Leopard join the market this advantage today no longer exsists. You don't want to hear my sad story with Align 600 motor. It ended up with a nice looking white magic smoke in my 1/8 buggy after only approx. 1 minutes of its debut run, and that wasn't a hard run. The cooling jacket does very little help if any. The motor will soon become a warm hearted cold man who's really warm inside. Actually you can tell what they're capable of by just watching the 3 slim wires.
    May 2010
    MO
    3,278
    Thanks,Mad.This one will be going kind of slow.Have to save up for a few parts Im lacking.
    May 2010
    MO
    3,278
    Hull has been stunged.Got the stingers mounted.Still have to mount the strut/rudder for the center.Im also open to outrunner motor suggestions.Im kind of paranoid about the Aligns with amp draw/heat.Wouldnt mind running Scorpions,but dont know which ones.Id like to have 1800kv motors for 6s running.Any ideas?
    May 2010
    MO
    3,278
    Got the strut/rudder mounted.These pics are just mock up with props stuck on for pictures.Its pretty tight back there with 3 X447's hanging there.Im hoping to get the rest of my parts soon.Im kind of getting excited to run it now after seeing 3 props on it.
    Oct 2010
    MO
    194
    Now don't take this the wrong way Larry because you've been doing this fe thing longer than me but I'd like to ask a couple of questions. Just doing some 'what if' math with some good 30-40c cells. 1800kv x 3.5 x 6 puts your motor @ 37800 rpm. Are there props that can actually move water and ultimately your boat at that rpm? And how much energy will be wasted and turned into heat if the motor can't reach the sweet spot? With that said I used to set up my 12s heli for a given head speed and selected motor kv based on what I KNEW that head speed was. You've been playing around wit these cats and have an idea of what a certain prop will do with so many cells in a boat that weighs whatever. There's my 2 cents and btw scorpion has some sweet new motors if you can shoehorn 40 mm in that hull 3 times or if you know something you'd rather not share here's the 30mm motor I ran in my 500,,, http://www.scorpionsystem.com/catalo...S-HK30-1900KV/ Just plain stupid power on 6s. There is something to be said for 1400 watts x 3=4200 for sure. I want to see this boat fly, I'm very interested, actually excited and wondering if grown men should be this excited about toy boats
