I can't seem to find it anywhere. My LHS has piano wire only.
I need this for my MHZ Mystic C5000 M, and I've never done anything with wire drives before so I'm clueless
SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
contact Jeff Wohlt on here...he's the wire man!
-Kent
"Will race for cookies!"
IMPBA D12
My Gallery: https://forums.offshoreelectrics.com/album.php?u=1738
Did you try McMaster.com?
They have three different pieces of 2mm stainless rounds 1 meter long.
304 is product number 1272T11 and $3.18 each. Diameter tolerance is +0/-.025mm, but that shouldn't be too critical for a wire drive, would it?
Brian
another one for McMastercarr.com
Is it a straight shaft or does it actually need to bend?
Billy Graham
You can get really good 2mm SS wire from the bicycle guys. Google 14 gauge ss bicycle spokes.
Ray
Thanks! The McMaster wire looks good. It will need to bend a little I believe.
Also, what size Teflon liner and stuffing tube will I need?
I appreciate the help :)
If you need it threaded on the end I can send you a few spokes.
Jon
Dom, are you sure that 2mm wire will be ok on a 44" boat?
FE BOATING: Less like a hobby and more like an addiction!
Thats .078"....
http://www.offshoreelectrics.com/pro...rod=jw-wire078
I don't think I need it threaded since I have the scale drives. The shafts are for 2mm wire, you just have to glue the wire in there with loctite.
I hope it'll be alright, that's what MHZ recommends. The scale drives I purchased for the mystic from MHZ have the 2mm drive shafts on them, so I'm guessing they'll work.
How long do you need?
Jon
Hmm, not sure. I haven't started the build yet since it's my Christmas present didn't make any measurements yet. Probably like 10-12" though. And I'm only guessing.
I have a pile of 258mm spokes, so with the threads and j-bends cut off that would give you about 10" exactly.
OK I was just wondering. I am not used to the bigger builds. If MHZ recommends it I'm sure it will be fine.
Thanks j.m. :) I'll let you know if I decide to go with those, gotta do a bit more research first.
I sure hope MHZ is right, haha. Will the wire from McMaster allow a slight bend?
And can some please let me know the size of the Teflon and stuffing tubing I will need? :)
I didn't use a teflon liner on my 2mm (which is .078) wire drive just a good ole 3/32 brass tube. Never had any trouble and never leaked a drop. I'm not a fan of liners and wire to brass tube has less friction than a teflon liner.
I would just buy the wire shafts from OSE! They are made by Jeff Wohlt
Mini Cat Racing USA
www.minicatracingusa.com
Hey RayR, where did your comment go? I was gonna reply to it and it disappeared, it had some info I needed :)
Like I said (and sailr)................contact Jeff Wohlt......
IMPBA D12
Oh alright! I wasn't sure if he could get me just the wire. I will contact him now :)
I agree! To each his own....I am still divided on it. I think the smaller boats are better with the liner....bigger without IMO.........
IMPBA D12
I use grease no matter what, but I also have been using good 'ol 3n1 oil to add to the grease...just grease it and drizzle oil down it and slip it in........good to go bro!
IMPBA D12
Sounds good! I have that Grim Racer grease, so I'll use that and then I'll get some 3n1 as well. Thanks for all of the info! Hopefully Jeff will respond and provide me with some wire :)
Where can I find 3/32 stuffing tube?
Grim stuff is what I use (also Prather) perfect!
You can get the brass through Steven (here).
Jeff is pretty darn good at getting back to me....just give him a little while....
IMPBA D12
I don't see any 3/32 here though
I've got time, so he can take his time, haha.
I found the 3/32 stuffing tube at TowerHobbies :)
