Results 1 to 4 of 4
Thread: 150 etti ESC Configuration
    May 2010
    NS
    237
    Default 150 etti ESC Configuration
    Hello All,
    Can anyone shed some light on the wiring for a Capacitor bank to the ESC?
    There is a plug point on the ESC with 2 wires, is this the connection point?
    Thankyou for your input.
    Mick
    Jan 2009
    WA
    45
    Here is an install picture.
    http://www.offshoreelectrics.com/pro...tti-caps-3.jpg
    As close to the esc as possible.
    Cheers
    May 2010
    NS
    237
    Ok thanks, this changes the setting up considerably
    Any idea's on what the extra 2 wire pin plug is for then?
    Mick
    Jan 2009
    WA
    45
    I believe its an RPM sensor. But it must use the ETTI Power analyser to work. I havnt used it but it would be good to know the Revs of the motor to se if your pushing it too hard.
    Cheers
