Results 1 to 3 of 3
Thread: Leopard for 6 or 8s
    Br
    2,406
    Default Leopard for 6 or 8s
    Just after some input for a rigger, what do people think of the 5692 1090kv on 8s 1p 5000mah 45c ?As well as the 5692 1340kv on 6s 1p 5000mah 45c?
    It is one of these that has come into my hands via P.Duggan https://forums.offshoreelectrics.com/...ead.php?t=8609
    Was thinking a 1527 1y on 6s but would like to go 8s. I know the 1.5y would be good on 8s but $$$$$$$$$$$$$$
    Any input would be great guys.
    Andym
    2,731
    With a 2" high tub the 56mm diameter leopard will need a bubble canopy even if you don't put a waterjacket/coil on it and have an S bend so you can lay it down flat, I would use something smaller in diameter.
    We have a supercat class over here for 8s1p 6min duration, most of us are on about 1200KV, I run a 1521/2.5d in mine with an X642 but it works well sprinting for fun too with an X646.
    Br
    2,406
    The hatch is not a problem, can make it to fit no problem. x646 smaller than I plan. Thinking more along the lines of 1460 or there abouts. Only need 2min run time
