Results 1 to 6 of 6
Thread: using hardcase packs in boats
    Aug 2009
    On
    422
    Default using hardcase packs in boats
    Was looking at the Turnigy 2s packs and noticed the 30c hardcase packs are
    $5.00 cheaper then the equal soft pack so if i ordered 6 packs you save $30.00.
    My question is does it matter running them in a boat or could you take the case off and reshrink wrap them?
    :canada
    On
    7,279
    If they fit, why would you take the case off....use them as is.
    May 2010
    MO
    3,278
    I agree.No problem with a hard case in a boat.
    Aug 2009
    On
    422
    Thats good I think they fit better because the wires come out the end rather then off to the side.
    :canada
    Jan 2010
    WA
    104
    The problem I had using hard case packs in a P Spec JAE was the size of the connectors and having to have twice as many to run 4 cells they get warm and cause a loss of performance.
    Jul 2010
    ON
    544
    I've been running hardcase packs since I started running FE in June, I'm going to crack them open this winter and re-wrap them in clear heat shrink for 2 reasons:
    1) Unnecessary weight
    2) When they get wet you can't see if there is any water trapped inside.
    Quote Originally Posted by ezhitz View Post
