I just got back from running my boat today, and noticed when the boat is on plane and running full speed, the water seems to slow or stop coming out of the water outlet... When i slow down then water comes out great... Is that normal????
Are you running stock cooling, (Rudder Only)
Make sure that water actually IS coming out.
I recently had a bad experience with my SV cooling. Smoked my motor in the end, cause my rudder water pickup was clogged. Make sure that it is clear by blowing into the top. I just got the transom water pickup and have yet to try it out, but it looks promising. Also, I had no idea that water wasn't coming out, since sometimes it looks like it is from the side.
Ya it's the stock rudder one.. i can see water coming out at lower speeds, but not at top speed.. maybe the water inlet is lifting out of the water at full speed.. I have a UL-1 motor so it really cooks...
the rudder pickups kinda blow. i have an sv with ul-1 motor too. i use the http://www.offshoreelectrics.com/pro...od=dh-aqub9520 and it works great
oh what prop are you using? i use the grim 40/52/3
I have the CF 42... and that boat really cooks.. can't wait to get a metal prop..
Well if i go that route, i think i'll pick up the trim tab and water pick-up combo..
i was using an x440/2 which got it out of the water real fast and seemed a little faster but made the boat more unstable for some reason. when i run the three blade prop it runs real smooth. i hear the 40/52 i real close to the x440/3 but i would like to get the x440/3 when theyre back in stock. i think it may be a bit faster. also someone told me to try an x642... but i dunno bout that. thats alot of pitch for a high rpm motor. prolly a bad idea
there is a combo?
X642 and Grim 42X55 were recommended to me by Diesel.... but in the mean time i got the CF-42 cause you don't have to balance and it's cheap!!! lol.. I need to work on the CG and the trim tabs on my boat still. It's own wake almost makes it flip.. In fact it did flip it...
Knitec has the trim tab combo...
i bought the kintec trim tabs adjusters. theyre awesome
don't they have a water pick up on them dana????
no i bought these
I've heard some people drilling out the stock rudder one, to make it a little bigger.
Well... i just looked at it, and it seems lower then the transom so i don't understand why it isn't picking up water at top speed... I think the water pick-ups that are mounted to the transom would be higher then the rudder one...
Are you sure the water isn't just splattering in the wind? Never had any problems running full systems off rudder pickups.
Well.. at it come rippin by me i don't see much water coming out.. but if i get off the throttle a little.. water comes out like crazy..
I was just told.. at high speed, it might be dripping out and thats ok.. i might get the trim tab water pick-up combo or drill the hole a little bigger...
I'm also starting to think that it might just be the fact that the boat is coming out of the water at high speeds. It shouldn't be a problem, since it is getting water on the turns and at a lower speed.
I would go with the trim tab water pick-up combo, you get two great upgrades that way.
Ya... since i need better trim tabs.. and a port turn fin! lol
Haha, good idea! I think the turn fin will be my next upgrade.
I almost put an ammo 2300 in my SV but was told the UL-1 is a good motor and runs cool.. and for just getting back into boat again.. this one is plenty fast... gotta be doing close to 45mph..
