Have not seen motor mounts for the Castle 1515? Curious to know what guys are using? Or what fits? Thanks
HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
Same motor screw spacing as a 540 can. southriverrcboats.com has rail mounts.
You can use the clamping style mounts designed for the Neu 15xx series if you remove a few of the fins. The first one and the last 2. But its tedious work with a file. Still, you save something like 25 bux or more from the "other" guys clamping mounts and its rock solid!
John
Change is the one Constant
Thanks guys for all your input.
