Results 1 to 6 of 6
Thread: Best Epoxy?
    NH
    183
    Default Best Epoxy?
    Hey Everyone,
    Been building a few cats and using different types of epoxy. I like the marine grade epoxy from loctite, does get a bit expensive.
    What does everyone else use or recommend?
    Has anyone tried the 3M 5200 marine adhesive?....comes in the caulking style tube.
    Thanks!
    Scott
    nc
    792
    Scott, everyone has been useing the Z-poxy to coat all the wood on the SV's. Reading the lable it says also used with fiberglassing etc. It dont as brittle as regular epoxy. It has a long working time to. Its not the expensive like 16 bucks for 2 big bottles. It dont smell either.
    Wa
    5,905
    West System Epoxy
    Rochester, MI
    81
    I would NOT use the 3M 5200. I would also use the West System epoxy. It is very easy to use. Just one pump of the Resin and one pump of the Hardener.
    Nj
    4,735
    5200 is heavy and a little to agressive for an rc app IMO. Not only that the cure time is just under a decade. Once it does...a 10 mega ton explosion won't remove it.
    wa
    1,384
    Ive had unbelievable results with EVERCOAT medium epoxy myself. Sold at professional auto body store supplier. Flows out nice and is sandable.
