Hello All
Hello All
This is my 3/16" shaft (for 3/16" bore Props) Propeller PropBox.
It is very durable and is a great way to store your valuable props.
This box will hold 60 props and has a place to store prop nuts and such.
The box is:
15" wide x 12 1/4" high x 6" deep.
The props are protected on the bottom section by foam pads under the prop
& foam pads under the second tier shelf.
The props on the second tier plate are protected under the prop & from the
thick foam on the underside of the lid.
The box and the second tier plate both have rubber bumpers under them.
For under the price of three props balanced, cupped, sharpened & polished,
you can protect 60 props, though I do not know all the different props that a
person may have you might be able to double stack the smaller props for even more than 60 capacity.
$115.00 plus S & H
