Results 1 to 7 of 7
Thread: Swordfish 120 wont go to full throttle!
    Jul 2010
    fl
    656
    Default Swordfish 120 wont go to full throttle!
    Anybody else had this problem?
    Mar 2009
    MI
    6,453
    Is it programmed for the correct voltage?
    Jul 2010
    fl
    656
    i think so.
    I have that little card with the dip switches.
    Could that cause it?
    Oct 2009
    NC
    4,204
    Did you do the throttle calibration?
    - Diesel's Youtube
    - Diesel's Fleet
    Jul 2010
    fl
    656
    Calibration was done a while ago.
    it worked properly then this problem came up.
    is there away of re calibrating?
    Thanks all for the help.
    Oct 2009
    NC
    4,204
    Quote Originally Posted by britscoot View Post
    Check all the connections first if all are good re-calibrate the throttle. The re-calibration is the same as the first time you calibrate.
    Pistol style transmitter calibration
    - Correctly connect the ESC with brushless motor, plug the receiver lead of ESC into receiver ( usually into
    Channel 2);
    - Put the throttle to the forward full position, turn on the transmitter;
    - Power on the ESC, there are 3 beeps emitted from the motor, which indicates all electronics are correctly
    power on for the setting.
    - Then there are 4 long beeps emitted from the motor ♪ ♪ ♪ ♪ .
    - During or after the 4 long beeps , move the throttle to the neutral position. Two beeps emitting out
    indicates calibrating is completed.
    - Following two beeps are powering beeps, it is time to go now!
    - Diesel's Youtube
    - Diesel's Fleet
    Jul 2010
    fl
    656
    Its not beeping but i get throttle.
    Just not full throttle.
    Whats the correct settings ie cut off etc?
    I sometimes get a red light on the esc when i pull the trigger to full.Motor spins.
